Author Topic: CB750K Rearsets - my solution  (Read 6948 times)
Offline .RJ
  • homebase in your airspace
« on: December 14, 2007, 05:03:50 PM »
- RC51 rearsets, $50 for the pair
- VFR Shifter, "borrowed" from my roomates parts pile
- Aluminum spacers from McMaster (1" up top, 1/2" on bottom)
- 1-1/8" frame clamps
I need to get some longer bolts for the lower mount, but its all ready to go.  Foot position is about the same as my daily ridden CBR with track rearsets.
I had set the rearset position with some flat stock to make sure I wanted them there before putting holes in my frame
This is what i had done originally, 2 frame clamps on each side, and the foot position was just awful.  No way was that going to work.
Offline FunJimmy
  • Who you calling
  • Vancouver
Re: CB750K Rearsets - my solution
« Reply #1 on: December 14, 2007, 05:26:59 PM »
Everyone shows the shifter side. How about the brake side.
That's the difficult one.
Offline .RJ
« Reply #2 on: December 14, 2007, 05:33:03 PM »
Yes, it is... and there's no pictures because its not done yet  ;D
I flipped the brake lever on the drum upside down, and i'll probably put a set of rod ends on each end - one more thing to figure out.
Offline tsflstb
« Reply #3 on: December 14, 2007, 09:31:28 PM »
It's amazing somebody in a garage across the country is doing the same stuff at the same time I am.  Gotta love this place.
You've got a good solution there.  I've had rearsets sitting on the bike for a couple of days with those same frame clamps.  I'm like you - at first it felt pretty good, but the longer I sit on it the more I think my knees would hate me after an extended ride.  1" lower and 2" farther forward would make a world of difference.
I don't have easy access to a welder, but I might need to do something differnt besides the frame clamps.  Did you just drill straight through the frame and use a long bolt?  Any worries about weakening the frame there?  I'd like to position the pegs similar to yours and my 400 has about the same layout.  Only thing is I'd have to commit myself and cut off the stock brake pedal bushing/housing thing on the right side.  I'll probably do that anyway, it's just a bit of a leap I guess.
Are you using a shift linkage or are you going with GP pattern?
Oh yeah - I'm starting on the brake side.  Hopefully I'll finish that while I'm still motivated and the shifter will be easy.
« Last Edit: December 14, 2007, 09:35:31 PM by tsflstb »
Offline CrisPDuk
  • Christ on a bike! Me, an
« Reply #4 on: December 14, 2007, 09:50:40 PM »
I've bought some Hayabusa rearsets for my 550, I'll get some pics up next week when I start :)
I've also completely chickened out of doing the brake side, I'm going disc brake at the rear using the busa M/C ::)
1978 CB550 K3
1985 H100S
Offline ekim98
« Reply #5 on: December 14, 2007, 09:59:31 PM »
I just got some cbr1000rr rear sets and haven't decided if I'm ready to tackle that project yet. I'm not sure which way to go either - brackets or drill thru the frame.
Patriot Guard Rider - KY. Ride with Respect
78 750k  cafe bike sort of
67 305  Superhawk (working project)
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #6 on: December 14, 2007, 10:00:07 PM »
got a link for where you got the frame clamps?
Offline SEBNN
« Reply #7 on: December 14, 2007, 10:36:55 PM »
I like the mounting location idea.  Being as my frame is still in the welding on mods stage, mind if I borrow your idea and modify it a little?  I tried tabs, but short of a really big mounting flange I would be unable to get the rearsets at the proper angle for the way that they were designed.
As for rear brakes, I am also going disk, using a cbr mc, caliper, mount, and disk.  I will need to modify the hub and the swingarm a little to make it all fit.  But, no more adjusting brakes!
Offline .RJ
« Reply #8 on: December 15, 2007, 06:28:25 AM »
Yep, straight through the frame - Its behind the swingarm pivot and I dont think a pair of 8mm holes is going to be a big deal :)
Reverse shift.  Better than linkages :)
That was the problem with the first arrangement, other than the position - they wanted to hinge up way too easily when I sat on the bike.
I had the dealer order them for me - they're 3 piece, about $8 each.
Offline SEBNN
« Reply #9 on: December 15, 2007, 08:47:48 AM »
By hinge up, are you refering to the mounts or the pegs?  I can see the pegs moving when you put your feet on if they are rotated out of position, though I hadn't thought of that before.  Good to know in advance though.  I will make a small triangle to go in between the frame tubes and another one to weld on the lower side of the rear triangle tube.  Hmmm, while I'm cutting and grinding I may just move the rear triangle, but then again, maybe not.  Anyways, it looks good, nice way to mount them up.
Offline ohiocaferacer
  • www.OHIOCAFERACERS.com
    • OHIO CAFE RACERS
« Reply #10 on: December 15, 2007, 10:47:10 AM »
Derek,
What going there buddy, how's life up north?? You can get those clamps at DennisKirk.com
Heres the link:
http://www.denniskirk.com/jsp/product_catalog/Product.jsp?skuId=&store=Main&catId=&productId=pH27037&leafCatId=&mmyId=
Later,
Greg
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #11 on: December 15, 2007, 10:51:29 AM »
thanks
Offline .RJ
« Reply #12 on: December 15, 2007, 11:27:22 AM »
DK shows 1 on hand, I think thats why I didnt order from them.  The dealer that trued my wheels ordered them for me, they had a bunch of catalogs of stuff... I just told them what I wanted and then found it for me :)
The pegs would hinge up - not exactly confidence inspiring, the way they're mounted now is about how they would be if they were on the RC51.  If the pegs were solid mounted to the holders, then this wouldnt be an issue, but they were still too uncomfortable - I tried fitting the rearsets from my SV650 (fixed pegs) and it wasnt really any better.
Offline .RJ
« Reply #13 on: April 11, 2008, 08:22:07 PM »
Better late than never?
« Reply #14 on: April 11, 2008, 08:37:49 PM »
You need the 2" Comp Baffle in there. ;) ;D
Offline .RJ
« Reply #15 on: April 11, 2008, 08:45:29 PM »
Oh yeah?  Where do I get one?
I could uh... just run it wide open too  ;D ;D ;D
Offline Jinxracing
  • It's hot shit, not
  • '70 CB750 K1
    • The Hairy Nickel
« Reply #16 on: April 11, 2008, 10:49:59 PM »
RJ, quick question...
With the rear brake linkage hooked up directly like you have it, what happens to the rear brake when you compress/extend the rear suspension? Does it apply the brake for you or are you getting away with it? ;)
–Captain Horatio Hornblower
www.thehairynickel.com
« Reply #17 on: April 12, 2008, 05:59:35 AM »
Dynoman sells them or through your dealer (Parts Unlimited etc)
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #18 on: April 12, 2008, 09:31:16 AM »
Looks good. Should work just fine and those heim joints are a great touch.
Jimmy
Offline .RJ
« Reply #19 on: April 12, 2008, 09:40:06 AM »
Looks ok - both ends move free.
