Author Topic: CB750K, longer swingarm and harley rim  (Read 4173 times)
Offline .RJ
  • homebase in your airspace
« on: December 15, 2007, 06:42:19 AM »
Just an FYI for anyone else that wants to do this -
I used a 16" harley rim, 77-78 CB750K swingarm/brake arm, 77-78 sprocket carrier, stock 48T rear sprocket and 16T 10mm offset front sprocket (cycle xchange).  The rim was laced to the stock hub with a spoke kit, and the chain is 102 links (I think stock is 100 links?).  I had ordered a 108 link chain, and broke it down - if you want a longer wheelbase 104 links would have also worked.
Rim and hub, new bearings (all balls)
Chain clearance:
Big fat tire
« Last Edit: December 15, 2007, 06:44:03 AM by .RJ »
Re: CB750K, longer swingarm and harley rim
« Reply #1 on: December 15, 2007, 08:38:49 AM »
If you used late sprocket carrier on early bike  (76 or down) your chain is out of line. Check it with chain off to be sure.
Offline rbmgf7
  • 2>4
« Reply #2 on: December 15, 2007, 08:57:20 AM »
yup. i installed the 75K engine into my 78 chassis. with the 78 sprocket carrier on the hub, it was a good sprocket width out of alignment from the front sprocket. fixed the problem with a sprocket carrier from an earlier K. need a little persuasion to get the carrier into the hub.
but by your picture, it looks fine
Offline .RJ
« Reply #3 on: December 15, 2007, 11:23:32 AM »
That why I bought the 10mm offset sprocket :)
Offline bgfootball67
« Reply #4 on: December 15, 2007, 12:16:52 PM »
That looks sweet!  I go back and forth about whether or not I should have done my frame and rims in a color besides black.  That red really pops!  What size tires were you able to fit in there?  Also love the spoke pattern, all from the inside looks great.  Greg tried to do that on my rims, but was unable to get it like that due to the spokes.  Great work!
« Last Edit: December 15, 2007, 12:30:19 PM by bgfootball67 »
Columbus VinMoto
Ohio Cafe Racers website - http://www.ohiocaferacers.com
Offline .RJ
« Reply #5 on: December 15, 2007, 12:23:04 PM »
Tire is a 150/80/16 - looks like there's room for more, but I dont think you need more than that - 150 is probably overkill already, and I'd need a wider wheel... maybe down the road if I build another one I'll go wider :)
legendary
« Reply #6 on: December 15, 2007, 12:39:56 PM »
RJ,
       who makes that rear tire? Love the tread pattern!
Bike is really looking good....and like the other guys said..the red frame looks excellent.
Steve
Offline .RJ
« Reply #7 on: December 15, 2007, 12:49:42 PM »
Tires are pirelli sport demon - you can get them in just about any size to fit a CB I think -
http://www.ronayers.com/catalogs/tires/parts.cfm?secid=3&type=212
Offline azuredesign
  • Knupping pin
« Reply #8 on: December 15, 2007, 01:22:18 PM »
Any problems with lacing all the spokes on the inside of the hub? Looks great! I have a 140-16 on my bike and like it.
All best,
Ben
Offline .RJ
« Reply #9 on: December 15, 2007, 01:33:35 PM »
Thats how the kit was designed, I believe - there was just no way to lace them inside/outside like stock - there wasnt enough bend in the 'outside' spokes.  I have a set of spokes from buchannan that do lace up like stock, but I had them powdercoated and then decided I didnt want to go that way.
Thanks for the compliments all :)  I've got a local guy that does fantastic powdercoat work, so he should get the credit for the red!
Offline ralt12
« Reply #10 on: January 14, 2008, 07:32:40 AM »
Nice work--which shocks are those?? Where did you source them?
Vtec-Sauce
« Reply #11 on: January 14, 2008, 08:36:06 AM »
so its an aftermarket swing arm or the newer 750 swing arms are longer that the early models? Would a 750 swing arm bolt into my 500 frame?
Offline .RJ
« Reply #12 on: January 14, 2008, 10:42:33 AM »
Its the swingarm listed in the first post...
The shocks are from a CB900F - I picked them up on ebay for about $150 shipped - seemed to be the going rate when I bought them.
« Reply #13 on: January 14, 2008, 10:59:50 AM »
I bought a set off Ebay recently and paid $85 (+ shipping)..they wont fit on my CB750K2 with stock exhaust so will be selling them if interested.
PM me if you are.
cheers
Andy
Offline jdawg
« Reply #14 on: January 14, 2008, 05:28:30 PM »
Andy - i'm interested - pm sent
1974 CB750 K4 - old junk to fiddle with
fuzzybutt
« Reply #15 on: January 14, 2008, 06:00:34 PM »
All best,
Ben
good eye
