Author Topic: Carb question  (Read 749 times)
Offline Pwfyrcat1
  • What I'm doing when it's warm
Carb question
« on: December 17, 2007, 02:48:46 PM »
Here is a picture of the carbs I scored.
Someone took the liberty of etching numbers on the bowls: 2, blank(1), 3,4
Is that the correct numbering sequence?  Is the numbering sequence the same as the table listed in the FAQs?
http://www.motorcycleproject.com/motorcycle/text/specs.html
I have a manual around here somewhere.
Is there anything particular I need to know before starting in to them?  Oh yeah, I know to do them one at a time.
as always, thanks;)
Just because you can, doesn't mean you should;)
2002 Yamaha Warrior, solo/souped/slammed/fast
2004 Yamaha V Star Silverado, 'The Sedan'
1992 Yamaha TDM 850
1975 Honda CB400F basket case that wants to be something
Offline 750goes
  • it will live
Re: Carb question
« Reply #1 on: December 17, 2007, 02:57:50 PM »
just swap the bowls for 1 & 2 if you want to....the drain screws should point to the outer side...
Offline KB02
Re: Carb question
« Reply #2 on: December 18, 2007, 04:48:00 AM »
Actually, if we are looking at the side of the carbs that connect to thee engine, then #4 is on the wrong side. As we look at them in the picture, it should be 4-3-2-1.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
