Author Topic: wheel bearings  (Read 2884 times)
Offline KRONUS0100
  • MAD MATT THE MANIAC
wheel bearings
« on: December 18, 2007, 12:15:14 PM »
how many bearings in the rear wheel(comstar).  Everybody i checked with sells them as a Pair.  My clymer manual clearly shows 3 bearings in the picture(exploded view). I am getting ready to change them and wonder what price i will eventually pay for not changing that 3rd one? Any one even know what size it is?
MATT
Offline dusterdude
Re: wheel bearings
« Reply #1 on: December 18, 2007, 01:28:08 PM »
i think 2 in the wheel and 1 in the sprocket carrier
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline cafe750
  • If you can't fix it with a hammer, it's electrical
Re: wheel bearings
« Reply #2 on: December 26, 2007, 09:30:18 PM »
The third bearing is a 6305z, you should be able to get it from an industrial bearing supply. Or, All Balls sells a whole kit, with seals and bearings.
"It's an old motorcycle, the wind is supposed to blow your head around, it's supposed to leak oil, the brakes should suck, and every now and then, it should scare you so bad you piss your pants."
Roy, Washington
