So I recently got a 1979 CB750 Limited Edition on a trade, to compliment my '78 that I am working on restoring, and while I know that this one is not a SOHC, it is still very similar, and so I decided to post here... I took it for a spin the other day and now I have a couple of questions:
-1- Apparantly, one side of the head gasket is leaking tiny ammounts of oil (you can see the gasket saturated in oil, thats it)... it also isn't the smoothest running engine, it slightly revs up and down when riding, which I also attribute to the gasket leak... One question is how bad is it to ride around with such a gasket leak? Can something inside be getting damaged in ANY way (like because of the lower compression on that side or smth similar)
If it is ok to lightly use for the time being, when does become damaging to the engine??? I will not have a chance to pull the engine for a little while, but I still am johnsin' to go riding around...
Am I correct that I have to pull the engine to change the gaskets? what else is usually recommended to do at the same time since everything will be taking apart?
-2- Another issue is the clutch... It only grabs at the very end of the lever... it seems to be adjusted right, as in the cable and the bottom lever move as soon as the handle-bar lever is depressed... however, the clutch itself does not engage (or is it dis-engage?) until the last quarter of the cable movement... I am not sure if its just 75% worn, or if something is misadjusted internally... any ideas? again, if the clutch needs replaced, anything else that should be done at the same time???
Thanks in advance for your insight, guys!
