Author Topic: removing handlebar grip - how?  (Read 15523 times)
Offline gregwaits
  • Damn, riding a CB750 sure is fun!
    • waits music
« on: December 18, 2007, 11:54:55 PM »
I swapped out the handlebars on my CB500 tonight. It was a wrestling match at times but I got it done....almost.
How do I remove the left hand grip? With a blow dryer?  ???
Thanks!
1978 CB750K8; 1970 CB450
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
Re: removing handlebar grip - how?
« Reply #1 on: December 19, 2007, 12:32:56 AM »
razor blade ;D
Offline 750goes
  • it will live
« Reply #2 on: December 19, 2007, 12:57:08 AM »
pour boiling water over it...then use a towel to grab it and twist it off....simple......... :)
Offline gregwaits
    • waits music
« Reply #3 on: December 19, 2007, 04:10:04 AM »
Great! Next, installing it on the new bars. What kind of glue do I use?
Thanks again
Offline cb350twin
    • http://mail.google.com/a/sohc4.net/
« Reply #4 on: December 19, 2007, 04:12:56 AM »
In my case glue wasn't needed.
1975 CB 750 K5
1972 CB 350 Twin K4
1972 CB 500 Four K1
Offline Jay B
« Reply #5 on: December 19, 2007, 04:28:00 AM »
An old trick is to use your wifes hair spray. Lubes it up going on, dries hard enough to keep it there but you can still get it off if need be.
Jay
'77 CB550K
'74 CB350F cafe
2001 Road King
'73 CB175
Offline Buber
  • A bit of spanner spinner, but definitely not a
  • #820 on old mailing list.... :)
    • Mountain Chalets in Polands
« Reply #6 on: December 19, 2007, 05:59:42 AM »
My method for taking off, was to poke with long, thin screwdriver, and while screwdriver was in, spray some WD40 in, and start twisting. It will be off under a minute.
Welcome to my mountains!
Mountain Chalets
Offline dusterdude
« Reply #7 on: December 19, 2007, 10:22:28 AM »
blowtorch and swiss cheese
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline miles nowhere
  • motorbikeist
    • Miles Hunsberger Tattoos
« Reply #8 on: December 19, 2007, 02:01:38 PM »
...or stick the air line in the right hand side of the bars ..shoots the left grip right off..
78 cb 750k8, 78 cb 750F3, 78 cb 750F3, 74 cb 750k4
Offline Blueridgerunner
  • CB650 no longer, but do have an 87 GL1200
« Reply #9 on: December 19, 2007, 02:05:35 PM »
Air hose, either way
Said James "In my opinion,  there's nothing in this world, beats a '52 Vincent and a red headed girl"
Laissez les bons temps rouler
Offline sandcastcb750
« Reply #10 on: December 24, 2007, 10:31:23 AM »
Take a knife, slit the old grip sideways/longways, peel it off. Buy new grips. Get on with your life.
Offline ofreen
« Reply #11 on: December 24, 2007, 10:41:11 AM »
The WD40 trick works.  Just stick the straw under there and squirt some in.
Greg
'75 CB750F
Offline 78CB750CAFE
  • I'm not really an
  • Ride, wrench, repeat.
« Reply #12 on: December 24, 2007, 09:25:54 PM »
wd 40 if not cleaned up will let your grip slip.
Off- skinny long flat screwdriver under grip, shot of AquaNet (blue can) hair spray and some twisting will get off your grip and leave it intact. If ya don't want to keep the grip, just cut it off.
On- spray inside grip with AquaNet and slide on. That sucker won't move again after about 15 miniutes, so get it straight when you put it on.
Drew
newcbguy
« Reply #13 on: December 31, 2007, 11:22:29 AM »
spray paint works well also to install new grips.
Offline boulder74
  • '75 CB 500 Cafe...almost done
« Reply #14 on: May 11, 2010, 08:08:16 AM »
I used rubbing alcohol, poured it in the grip, slid it on and it evaporates.  It cleans the inside of the grip and so my grips have been sticky and stayed put ever since.
have fun!
Offline 78CB750CAFE
  • I'm not really an
« Reply #15 on: May 13, 2010, 11:20:16 AM »
ALCOHOL IS THE MAIN INGREDIENT (oops caps lock) in hair spray, so same effect.
Offline Gordon
  • 750K1, 550K2
« Reply #16 on: May 13, 2010, 11:38:38 AM »
Same effect, plus extra stickiness. :)  I'm a big fan of Aqua-net, too.  I wonder if there's money in buying a bunch of cheap, generic hairspray and re-labeling and marketing it as grip adhesive? ;D
A good method for removing grips that are stuck on with hairspray is using an air compressor with the ball-inflator needle.  Just slide the needle under the edge and inflate.  It pops the grip right off and will even shoot it across the garage if you're not ready to catch it.
« Reply #17 on: May 13, 2010, 10:47:54 PM »
Razor knife to remove.
Think I used a little gasoline last time I installed grips.
Offline Gordon
  • 750K1, 550K2
« Reply #18 on: May 14, 2010, 07:40:52 AM »
Word!
Some folks are thrifty.
« Reply #19 on: May 14, 2010, 10:44:57 AM »
For an "Honest Prick" I'd have thought you could call me a cheap bastard  ;D
Offline Gordon
  • 750K1, 550K2
« Reply #20 on: May 14, 2010, 11:01:28 AM »
I try not to pick on the elderly too much. :P
Offline speedy_the_drummer
« Reply #21 on: May 29, 2010, 07:47:52 AM »
I cut my old ones off.
I used Carb Cleaner to get them back on. You have to go fast! It'll melt the rubber ever so slightly, which helps because they don't move at all now!
co425
« Reply #22 on: May 30, 2010, 03:57:54 PM »
For heated grips you would have to use high temp rtv. For regular the hairspray works great.
Offline Stutters
  • Special Ed
« Reply #23 on: May 31, 2010, 11:21:35 AM »
I've found Fontina works the best but swiss is a fine substitute. Do not use cheddar, Yamaha yellow does not agree with stock Honda bars
CB750K8
"Let's do something stupid together!" - R.Thompson
