Author Topic: Side Cover Tab Repair  (Read 1862 times)
Offline Burke
« on: December 19, 2007, 05:02:17 PM »
I have looked all over for a thread on repairing the side cover tabs. Can some one point in the right direction?
I have tried many things to repair these with, epoxy, superglue other glues. Does anything really work?
Offline billdramp
  • DOOMTOWN RIDERS / PORTLAND, OR.
Re: Side Cover Tab Repair
« Reply #1 on: December 19, 2007, 06:18:33 PM »
IMO Your best bet (besides NOS, or aftermarket) is to put some fiberglass epoxy on the inside of the side cover and tabs... and change the bushings on your frame so that you do not keep breaking them every time you take them off. (don't ask me how I know.) :o
Cheers from Portland
Billy
1975 CB750K (daily rider), 1974 CB550K (sold), 1974 CL350 (sold), 1973 CL350 (when I get around to it...), 1971 CB750 (in boxes), 1978 CB750F in boxes, 1976 CB750F SUPERSPORT (sold), 1975 CB400 FOUR (crashed), 1976 400 FOUR (work in progress), 1977 cb400f
SOHC4  MEMBER #1527
Offline Johnie
« Reply #2 on: December 19, 2007, 07:31:27 PM »
I had a broke tab on my Wing and used JB Weld.  That was 4 years ago and it has held terrific.  There are other products people use, but JB Weld did it for me.  You can get it at your hardware store.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline cb350twin
    • http://mail.google.com/a/sohc4.net/
« Reply #3 on: December 23, 2007, 02:05:03 PM »
Some say super glue and baking soda mixed works good. I tried useing JB weld for mine didnt seem to work for me, probly cuz it was  cracked bad and brittle. Works great for other stuff though. Once David sliver spares opens back up for the holidays,  I,m geting theres.
1975 CB 750 K5
1972 CB 350 Twin K4
1972 CB 500 Four K1
legendary
« Reply #4 on: December 23, 2007, 06:11:24 PM »
Guys,
          my other interest...apart from this forum  :) Is model making.
You can use superglue and baking soda. It is extremely strong, it can be filed, sanded, drilled etc.
BUT, you cannot mix them and then apply it. The baking soda is basically a catalyst for the superglue. Put the two parts together apply the superglue and dust it with baking soda. When the baking soda touches the superglue....BANG! The combination is solid as rock.
The only drawback is that if you have excess baking soda in your mix it will remain reactive. If you paint over the bond over time the baking soda will work its way through the paint finish.
JB WELD is probably a better solution is this application..that stuff is tough and available in most hardware stores.
matt365
« Reply #5 on: December 23, 2007, 06:33:15 PM »
I've had good results melting cracks together with a soldering gun.  I'll reinforce the back of the split with fiberglass mesh, and fill the front with plastic filler.
