Author Topic: Lean angle of side stand. bent stem?  (Read 2635 times)
Offline cb750k7
  • My CB AKA Charlie Brown...(K8 frame with K6 engine
« on: December 21, 2007, 01:29:50 AM »
Hi all,
My bike is leaning to much when rests on it's side stand.
Since the center stand is broken (was broken during shipping) it is the only way the bike stands.
(You can see at the picture that it has arrived this way and the shipper had to "compensate" with extra stuff below the side stand to keep it upright)
My question is,  can I force the "stem" of the side stand to the right angle or will it broke?
I am afraid to heat it,  since it IS the frame and might deform.
Any advise will be appreciated.
Jona
Found real friends here !!!
newcbguy
Re: Lean angle of side stand. bent stem?
« Reply #1 on: December 21, 2007, 06:42:26 AM »
usually when the stand is like that its the actual kickstand that has bent and not the frame tab. the frame tab is made so that it is very ridgid. If it is infact the frame tab that is bent, heat away, but maybe consider bracing it up a little.
Offline Steve F
« Reply #2 on: December 21, 2007, 06:43:23 AM »
Those things can be found on e-bay all the time.  I think they're forged steel, and heating it and bending it back might not be a good idea.  Are the tabs where the stand mounts to bent in any way?  Is the pivot bolt broken or worn out?  Are the holes in the frame tabs and the stand out of round?  Maybe it's something other than a bent stand.
Offline dusterdude
« Reply #3 on: December 21, 2007, 06:47:57 AM »
when i bought my bike and it still had the 18 inch rim and stock shocks,mine leaned over bad,now with the 16 inch and short shocks it isnt so bad.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline cbass*gxc
    • My Pics Page
« Reply #4 on: December 21, 2007, 07:04:13 AM »
Hey cb750 I have the exact same bike and my kickstand is too long because I have lowered the bike about 4 inches.  If you want I would be willing to trade for you mine for yours.  You can see my bike here. http://jaypage.com/pics/motorcycle/Bike%2012_13_07.JPG  Anyways if you are interested let me know.
I even have my old center stand and all the parts.  You can have those as well.
« Last Edit: September 09, 2013, 09:40:48 AM by cbass*gxc »
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #5 on: December 21, 2007, 08:03:54 AM »
On my '77 CB550 I am using a CBR600 F3 stand. It bolts right up, is a lot lighter and longer than the 550 stand. When I'm finished the rolling chassis I'l cut (if needed) the stand and reweld the shoe at the ideal length.
Offline cb750k7
« Reply #6 on: December 21, 2007, 08:25:55 AM »
Thanks all for your replys.
The tabs seems to be in fine condition as are the holes.
I am afraid that mount is bent.
richardinhoxne
« Reply #7 on: December 21, 2007, 10:03:34 AM »
Hi,
My 1977 CB750 leans over quite a bit when its in its side stand - on mine at least part of the problem is the worn bolt and pivot holes which are really oval and allow a lot of side movement of the stand.  Not tacked this yet but fitting another slightly longer stand  or fitting a shoe to this one sound good. Bike sits up nicely if I put about 3/4" to 1 " wooden board under the side stand.
Offline crazypj
  • I'm brill, me
« Reply #8 on: December 21, 2007, 10:47:11 AM »
You all should check the width of slot where it fits over frame tab.
There is a specification for it which I think is 10 degrees.
If the mounting bolt has worn or been allowed to come loose, its a good possibility that the 'slot' part is too wide.
 A burr on the flat edge of pivot bolt can have the same effect
PJ
Offline KB02
« Reply #9 on: December 22, 2007, 05:17:22 AM »
Double check your frame, too. Sometimes a bend side stand is caused by the frame itself cracking and letting the side stand twist away from the frame. Hopefully that's not it, but check it out anyway.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
