Author Topic: best way to store a tank?  (Read 2701 times)
Offline mazingerzeca
« on: December 22, 2007, 03:35:46 am »
Hello all.
I bought a tank for my bike on e-bay, and it is in a very good condition inside. I'm not going to install it on the bike yet, so I would like to know the way to preserve the inside from rust until use it. Any ideas?
matt365
Re: best way to store a tank?
« Reply #1 on: December 22, 2007, 04:16:04 am »
fill it full of gas :D
Someone has to say it.
Offline azuredesign
  • Knupping pin
« Reply #2 on: December 22, 2007, 04:18:02 am »
If its already dry and clean inside, keep it a dry, heated ( in the north, at least when its above freezing) environment. Leaving the cap off probably helps as well.
Offline Jay B
« Reply #3 on: December 22, 2007, 07:38:46 am »
Coat the inside with 2 stroke oil.
Jay
'77 CB550K
'74 CB350F cafe
2001 Road King
'73 CB175
« Reply #4 on: December 22, 2007, 09:33:01 am »
High and dry. I leave the cap on (smear of grease on the gasket or topedge may be wise).....no sense in making your premises uninsurable by storing gas inside!!
Unless bare metal rusts in your storage are tank should be fine.
That and I pulled an old tank off the rack a while ago to look at something, assumed it was dry and imagine my surprise when a 1/2 quart of green foul smelling stuff was still in there, now that I opened it I had to drain in, and air it out.. what a stench..
« Reply #5 on: December 22, 2007, 11:33:54 am »
Thanks for the replays. I will coat it with 2-stroke oil... cheaper thank gas  ;D
Offline mgmuellner
« Reply #6 on: December 22, 2007, 11:40:31 am »
If it's got a nice outer finish, throw some bubble wrap around it too.
73 CB750
69 CB350
73 RD350
73 z50 (2 of em)
01 SV650
Offline SOICHIROSFOUR
« Reply #7 on: December 22, 2007, 01:06:00 pm »
I had a 35 year old NOS tank for an Italian bike that I kept it in the spare bedroom in my house. Cap on and no petcock and dry, covered with a baby blanket, after years never a speck of rust.
« Reply #8 on: December 22, 2007, 04:23:56 pm »
OOOhhhh is it a tank for a MACH 1 with the carb cutout by Chance????
 Did I win?? Did I win??
« Reply #9 on: December 22, 2007, 06:46:24 pm »
Nope it was for a Montgomery Ward Riverside Mojave.
« Reply #10 on: December 23, 2007, 03:24:12 am »
Is that a motorcycle or an Indian?  ;D
Offline Geeto67
  • A grumpy
« Reply #11 on: December 23, 2007, 07:12:15 am »
I store my nice originals and NOS tanks in the house (on display actually).
Maintenance Matters Most
Offline Bodi
« Reply #12 on: December 23, 2007, 08:53:43 am »
Two stroke oil is a good idea, but... any water that condenses inside the tank will sink under the oil at the bottom (oil floats on water) and cause rusting there. Filled with gas and a little bottle of gas line antifreeze (to dissolve any water that condenses) is best for a bike you will ride the next season. I kept a few tanks in an unheated shed for years, a friend suggested putting a handful of mothballs in an old sock, tying a bit of string to it, then stuffing it in the filler with the string out... then closing the cap on the string (so it could be pulled out later). I did this. The tank on a CB77 I had parked in there with no gas but otherwise untreated rusted badly. The ones with the mothballs stayed shiny inside.
Offline mgmuellner
« Reply #13 on: December 24, 2007, 08:28:28 am »
That's true for standing water - but most often you wont see much (if any) water.  It's mostly humidity.  Would humidity have the same result as standing water?  If so, what happens to the coating on the top of the tank?  If the inside is coated with 2 smoke oil & is somehow opened/vented so humidity doensnt condensate, then he should be fine I'd imagine.  Right?
73 CB750
69 CB350
73 RD350
73 z50 (2 of em)
01 SV650
Offline dkruitz
    • Dan's Antique Outboard site
« Reply #14 on: December 24, 2007, 09:13:25 am »
On my bike?  ;D
« Reply #15 on: December 24, 2007, 03:58:19 pm »
That "Moth balls" thing is interesting, there are two types apparently, naphthalene, and paradichlorobenzene.
Once you finish storing that tank, just drop the naphthalene mothballs in the tank and fill it with gas, and it'll increase the octane rating of the fuel! Don't use paradichlorobenzene though, or it'll turn into Hydrochloric acid (HCl) and eat your engines internals!  ;D
http://www.newton.dep.anl.gov/askasci/chem00/chem00485.htm
