Author Topic: Is this the source of my oil leak? (PICS!)  (Read 2036 times)
Offline Honda?
  • Made in the Midwest
  • BEER!
« on: December 22, 2007, 10:13:13 pm »
1978 Cb750K
20k miles
Anyways my bike leaks oil from the #2 exhaust port area. It has always seemed to be from the HG but now that I have gotten the cams off it looks as tho the oil leak could be from one of the rubber plug things under the camshaft.
My questions are does this seem to be the source of my oil leak? And should I go any further? HG?
Here you can see pretty well what parts of the engine the oil has been leaking onto.
This is the rubber plug thing that I found under the camshaft and rocker arms.
another pic. (dont mine the spider ;))
I have a 1970 CB350 SS, 1988 NT650(Hawk GT), 2004 BMW R1100S
Offline mkramer1121
Re: Is this the source of my oil leak? (PICS!)
« Reply #1 on: December 22, 2007, 10:34:54 pm »
Could be, partsnmore has those at ~$12 each?  (I may be really over quoting them!).  Is that spark plug rather oil covered?
When we rebuilt my 750, we used some Yamabond to hold the pucks in place.
Offline Honda?
  • BEER!
« Reply #2 on: December 22, 2007, 10:39:05 pm »
Yes when I pulled that particular spark plug it was covered in oil. I am hoping the HG doesn't need replacing.
I would still like more imput on this one. Because if I leave the HG and it still leaks I will need somebody to blame other than myself  ;)
Offline Dusthawk
  • Dusthawk & Rita IFO Phils Cafe, bestest Breakfast!
    • My MySpace Place
« Reply #3 on: December 22, 2007, 11:26:00 pm »
I just hauled out the head I have sitting here waiting to be put on Rita, in where those discs go, it would be a safe assumption that that is the source of the leak.
On a side note, when I used to rebuild Chev parts and engines, I used a gasket sealer called Ultra-Copper for its heat resistance and sealing abilities. Would that also be something that would be beneficial for Rita to seal her up?
1971 Honda CB750 K1 Chopper A.K.A. Rita
Build Thread: http://forums.sohc4.net/index.php?topic=86383.25
« Reply #4 on: December 23, 2007, 01:11:59 am »
Yeah mate, that's the source of your leak, you can buy those "pucks" from Z1 Enterprises for a couple of bucks each, and you don't need to go any further with your investigation. Clean up the holes and smear a little Threebond 1104 around the edges, and it'll be fine. Just make sure you don't get any sealant into the oil jets (also under the cam towers) or you'll cook your top end.
Jeff, there was discussion a couple of years ago on the "Greenspun" forum regarding the best sealant for these engines and the big concern was the dangers of "balls" of silicon getting into the oil system and blocking oil jets in the head, and even though Threebond contains a small amount of silicon, it was considered by the majority to be the favored sealant. The other good thing is that as it's a gray color, it's not noticeable on our silver cases. (Of course if your engine is black...............) Cheers, Terry. ;D
Offline Dusthawk
    • My MySpace Place
« Reply #5 on: December 23, 2007, 04:00:37 am »
I can understand where some might be conserned with the balls of it getting into the engine, but I learned a long time ago that with UltraCopper an Ultra thin shmear of it works best on most gaskets, and any that might squeeze out can easily be cleaned with a paper towel. It is just what I have the most experience with is why I ask.
Offline RRRToolSolutions
  • I love old Japanese bikes!
« Reply #6 on: December 23, 2007, 05:03:07 am »
Yes, that would leak for sure.
Guys, I suggest nothing but the Honda "sealing rubbers". I went with aftermarket the first time around --yea the 2nd time and the third time I used Honda exclusively on everything but the head gasket. Those aftermarket ba$tards leaked. Clean the sealing surface with acetone or lacqer thinner on a towel then put a trace of 1104/Hondabond to the edge of the recess where these sit. I've never had a leak since.
One more tip - if you remove those little 6mm studs holding the cam blocks in-place (shown in your photo), be sure to apply Blue Loctite to the threads. Even though tight, those will allow oil to seep down the threads and onto your spark plug base as they are drilled completely through the head (learned the hard way).
Here's that picture that is supposed to save me a 1,000 words -
Gordon
« Last Edit: December 23, 2007, 05:06:40 am by Ilbikes »
Kaws, Hondas, Yamahas, and Suzukis - especially Kaws
Offline Kevin D
  • SE Michigan
« Reply #7 on: December 23, 2007, 05:43:08 am »
I found'em for $2.33 each at Service Honda.
Please don't deplete their stock, I'm gonna need a batch of them myself! :D :D
« Last Edit: December 24, 2007, 06:47:56 am by Kevin D »
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #8 on: December 23, 2007, 06:20:34 am »
I've got a few of those left over from my 550 days.  I'll double check the part number but I'm sure they're the same ones.  Probably have 6 or so in the Honda packaging.
Anyone need 'em?
Offline Kevin D
  • SE Michigan
« Reply #9 on: December 23, 2007, 04:51:39 pm »
Anyone need 'em?
Go for 'em, ?. I'm a month away from making my parts order.
Hey, 96 tears is a great song, are you the same ? :
http://www.myspace.com/questionmarkandthemysterians
 ;D ;D ;D ;D ;D ;D
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
« Reply #10 on: December 24, 2007, 04:01:18 am »
I haven't tried the rubber seals in my CycleX "Emgo" gasket set yet, but the seals I bought from Z1 are OEM, as was the new camchain adjuster etc. Cheers, Terry. ;D
