Author Topic: Going to do top end rebuild.  (Read 2762 times)
Wes
« on: July 27, 2005, 12:08:06 PM »
Im sick of waiting for my engine to unlock, and I want to do this right so, im going to take my engine out and rebuild the top end. Sounds like fun. :P Do any of you know where to get rings/gaskets for cheap. Any advice would be greatly appreciated.
Offline clarkjh
  • Expert? If only.
  • Surely and Samson are now Co-habitating
Re: Going to do top end rebuild.
« Reply #1 on: July 27, 2005, 01:50:50 PM »
Wes
I know how you feel, I planned on doing my top end this winter.  Last week seen the white smoke coming from the exhaust and desided to rebuild the topend before I broke something.  My kit was over $100 Canadian, but I ordered it from the local Honda dealer.  Good luck on your rebuild.
“I’m pullen for ya”
          Red Green
SOHC/4 #3328
SOHC/4 Gallery: http://www.sohc4.us/gallery/v/members/personal/clarkjh/
1974 CB550, 40000 Miles
1980 GL1100, 102789 KM - Back on the road after a complete engine rebuild.
*** Why, oh why, is it always head gaskets with me?***
Wes
« Reply #2 on: July 27, 2005, 02:04:04 PM »
Do you have the part number off your top end kit? Is it standard or overbore? Did it come with gaskets?
Offline clarkjh
  • Expert? If only.
« Reply #3 on: July 27, 2005, 02:09:09 PM »
I don't have the part number.
It should be in tomorrow, when it comes in I will post the # and what I got for contents.
James
SOHC/4 #3328
Wes
« Reply #4 on: July 27, 2005, 02:20:20 PM »
Okay thanks alot. ;D
Wes
« Reply #5 on: July 28, 2005, 07:49:30 AM »
Has anybody had any proplems using the 555 kit for a 500 on a 550?
« Reply #6 on: July 28, 2005, 09:05:51 AM »
That Kit is exactly the same as a 2nd oversize (0.50mm) rebuild kit for the 550. You will still need a "top" gasket kit for all the other gaskets/"O" rings
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #7 on: July 28, 2005, 11:20:58 PM »
http://cgi.ebay.com/ebaymotors/Honda-CB500-Four-BIG-BORE-555cc-Performance-Rebuild-Kit_W0QQcmdZViewItemQQcategoryZ35595QQitemZ4565066962QQrdZ1QQsspagenameZWDVW
I have this exact kit, bought from the same seller installed on my 1976 CB550F.  It was put in 800 miles and 1 month ago and is running strong.
The pistons are ART branded - OEM maker for Honda so all is good.  0.5mm overbore on the 550.
They raised the price $20 after I got mine, but you should be able to get it for $100 + shipping.  A relative bargain for 4 pistons, 4 ring sets, 4 pins, a head gasket (nice one too) and 4 sets of clips.  The rings alone are $30 a set from Honda, and the pistons can't be bought new from Honda anyhow.
I wouldn't hesitate to get this kit for a 550, so long as you can get away with a 0.5mm overbore.
« Last Edit: July 28, 2005, 11:22:29 PM by tintin »
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #8 on: July 28, 2005, 11:27:24 PM »
Have your valves gone over too.  I found a local machine shop (specializes in valves) and they worked over my cylinder head.  Seated all the valves, replaced a couple of guides and blasted / painted the thing too.  I paid them CAD$150 cash for the job.
This is the after pic of the valves:
Offline Einyodeler
  • Midnight bugs taste best!!!
« Reply #9 on: July 29, 2005, 06:16:17 AM »
I am running the same kit on my 500 daily rider,it too sat open to the elements before I got it.
12,000 + miles on it so far this year and it runs like a raped ape.  :)
« Last Edit: July 29, 2005, 06:20:46 AM by Einyodeler »
1972 CB500 - 1973 CB500 - 1974 CB550K - 1975 CB550F - 1975 CB750F - 1976 CJ360 - 1983 CR480 - 1970 BSA A65T Thunderbolt
Download Motorcycle Shop Manuals here: http://forums.sohc4.net/index.php?topic=17788.0
Wes
« Reply #10 on: July 29, 2005, 09:24:09 AM »
Has anyone used the 605 kit?
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #11 on: July 29, 2005, 06:28:20 PM »
So you're running at the full 3.0mm overbore?  Does it run hot at all?  I wasn't sure if cutting that much of the cylinder sleeve out would be a problem or not.
« Reply #12 on: July 30, 2005, 09:38:16 AM »
The 605 kit is MUCH more expensive to fit, Liners changed then bored, top crankcase bored to take bigger liners so its a full strip not just top end
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #13 on: July 30, 2005, 12:11:22 PM »
The 605 kit on a 550 would only be a 2-3 mm overbore, like the 555 kit on a 500.  So, the new sleeves aren't needed.  However, I'd stick within the 0.25 - 1.0mm overbore options originally offerred by Honda myself.
