Author Topic: Carburetor Sync tool  (Read 2876 times)
Offline Blueridgerunner
  • CB650 no longer, but do have an 87 GL1200
« on: December 23, 2007, 05:51:41 am »
Will the motion pro carb adjusting tool the one that I need for my 81 CB650?
Clymer lists two different Honda Part numbers, one for earlier models and another for 81+.
(part number 07908-4600200). However, I can't seem to locate any more info using these numbers.
Said James "In my opinion,  there's nothing in this world, beats a '52 Vincent and a red headed girl"
Laissez les bons temps rouler
Offline OldSchool_IsCool
  • Really feeling like an
Re: Carburetor Sync tool
« Reply #1 on: December 23, 2007, 10:34:52 am »
About the only "model specific" piece of a carb sync tool is the size of the threads on the vacuum port adapter barbs.  If you get both 5mm and 6mm port adapters, you should be covered for many many many bike models.
No real secret to carb sync tools.  They just need to show the relative strength of each vacuum chamber.  Adjust the carbs such that the pull is the same on each carb.  The absolute value of the vacuum is unimportant, they just need to match.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
« Reply #2 on: December 23, 2007, 01:16:27 pm »
Thanks for the reply. I'm afraid that I wasn't too clear. I am looking to buy the motion Pro tool that looks like a long screwdriver inside a hollow shaft if it will work on my 81 CB650. The manual lists a different wrench for the 81 up so I need to know if this will work before I buy one. I already have the vaccum guage setup.  :)
Offline dustyc
  • I don't know why anyone would call me an
  • 1977 CB750K
« Reply #3 on: December 23, 2007, 04:40:46 pm »
The one I asked about in this thread says it's for Mikuni and Keihin carbs with 8mm hex nut and screw driver slot.
http://forums.sohc4.net/index.php?topic=29113.0  Do your carbs have 8mm nuts?
1977 CB750
« Reply #4 on: December 25, 2007, 09:46:03 am »
Probably. Can't say for sure as they are off in Texas getting overhauled.
Offline scott_cb650
« Reply #5 on: December 27, 2007, 10:03:06 am »
Is this what you are looking for?
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=230189562238&ssPageName=STRK:MEWN:IT&ih=013
Don't give up.
It took me a long time to find one this cheap on ebay.
You can find new versions for about $30 plus shipping.
Do a Google search for "tappet adjustment tool".
I found this one on the first try.
http://www.pitposse.com/tappettoolset.html
Scott
Why worry about tomorrow for tomorrow has enough troubles of it's own.
Offline scott_cb650
« Reply #6 on: December 27, 2007, 10:08:50 am »
