Author Topic: Engine cleaning  (Read 2133 times)
Offline Honda?
  • Made in the Midwest
  • BEER!
Engine cleaning
« on: December 25, 2007, 09:44:41 am »
Well I have my engine out of my bike and I've found the source of my oil leak. (one of the 6 rubber pucks under the valves)
My next task is to clean all of the oil and grime off of my engine which will be a pretty good job.
My question is if I were to use carb cleaner/brake cleaner/ or anything else like those two would that cause any damage to or eat through the HG or lower gaskets?
Any advice is appreciated
-Tyson
I have a 1970 CB350 SS, 1988 NT650(Hawk GT), 2004 BMW R1100S
fuzzybutt
Re: Engine cleaning
« Reply #1 on: December 25, 2007, 10:23:26 am »
do NOT use a pressure washer! it's too easy to blow seals out with one and put water where you dont want it. a scrub brush and hot, soapy water is all i use
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
Re: Engine cleaning
« Reply #2 on: December 25, 2007, 12:43:54 pm »
Varsol and a tooth brush.
Offline Bob Wessner
  • "Carbs Suck!"
Re: Engine cleaning
« Reply #3 on: December 25, 2007, 06:46:15 pm »
I've found a 50/50 mix of Simple Green sprayed on and allowed to sit for a few minutes, then a brush, followed by a rinse to be a very effective degreaser and cleaner. Repeat if necessary. Best on a warm engine (not hot), even the warmth of sitting in the sun would work, though I doubt that will work in WI right now. ;)
Re: Engine cleaning
« Reply #4 on: December 25, 2007, 07:08:38 pm »
How about simple old fashioned Gunk engine cleaner and a brush for the thick stuff.
Offline Honda?
  • BEER!
Re: Engine cleaning
« Reply #5 on: December 26, 2007, 12:12:42 am »
Bob Wessner,
I may be in WI but my engine is in a nice heated room upstairs across the hall from my bedroom ;)
I've tried my options and yes the gunk engine cleaner/degreaser works best by far.
Thanks for all of the help!  (now help me find a new cheap camshaft/towers/rockers for my engine.)   ???  "my options" thread
-Tyson
Offline Bob Wessner
  • "Carbs Suck!"
Re: Engine cleaning
« Reply #7 on: December 26, 2007, 02:58:46 am »
I used it once, had forgotten about that. It was very effective for sure, but it raised hell with our black-top driveway as well so I switched. Of course it was pretty badly in need of a cleaning back then. I try not to let it get that bad anymore.
Offline Jim F
  • go baby go
Re: Engine cleaning
« Reply #8 on: December 26, 2007, 06:20:15 am »
XJ-1 is what I have been using. Just spray it on and use a water hose with out the spray
nozzle  is all you need.
Its really good about taking stains off (Georgia red clay for all you Georgia folks)
Most dealers have it at around 25 bucks a gallon
Jim
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
Offline dkruitz
    • Dan's Antique Outboard site
Re: Engine cleaning
« Reply #9 on: December 26, 2007, 12:02:24 pm »
Purple Power from Walmart is good stuff - $5/gallon if I recall.
Offline mkramer1121
Re: Engine cleaning
« Reply #10 on: December 26, 2007, 03:14:25 pm »
I found using a steam cleaner first helps break up a lot of the grime and then your favorite cleaner and a toothbrush works out pretty well.
Re: Engine cleaning
« Reply #11 on: December 26, 2007, 03:18:37 pm »
Keep that steam cleaner (or pressure washer) away from wheel bearings, swing arm bearings or steering head bearings Mike, or you'll be sorry!
I destroyed the front wheel bearings in my BMW R100RS using a steam cleaner, it cleaned the wheels up fine, but it also washed all the grease out of them, and I didn't know until I got into a "tank slapper" at 80 Mph that anything was wrong!
I'd send you a pic of my undies as proof, but even now, I still can't bear looking at them! ;D
« Last Edit: December 26, 2007, 04:34:19 pm by Terry in Australia »
Offline mkramer1121
Re: Engine cleaning
« Reply #12 on: December 26, 2007, 03:55:47 pm »
Well, right, always regrease when done!  :D
