Author Topic: Leaking Master Cylinder Cap  (Read 1053 times)
Offline nomadwarmachine
  • 1972 CB750K2, 1974 Norton Commando 850 Mk2
    • Nomadwarmachine.com
« on: December 25, 2007, 01:05:29 pm »
After rebuilding my master cylinder (and adding stainless lines) a little while ago, I have recently developed a problem with fluid leaking out from under the master cylinder cap.  This appears to be associated with the vibrations produced by high RPMS -- at 7,000 it is practically streaming out from under the cap.  This happens regardless of how hard I screw down the cap.
I am going to order a new rubber diaphragm, since my current one has some tiny cracks, but I would be surprised if this is the cause.  Is it possible that I am putting the cap on wrong?  I always fill to the fill line, then place the black diaphragm on top, then screw on the cap tightly.  Any help or past experience is appreciated!!
Offline shoemanII
  • just another bike nut
Re: Leaking Master Cylinder Cap
« Reply #1 on: December 25, 2007, 02:09:09 pm »
is the front brake dragging more than is usual?  this may heat up the brake unit/fluid, causing some expansion of the fluid.  or maybe try taking some fluid out, say 1/4inch below the "fill" line.  don't really think we need a reservoir of that volumn anyway.............
good luck on this, sounds like you're still riding.  lucky you, just pulled the cylinder today for new top end gaskets/ "o"-rings.
bobp
'96 ducati carb'd 900ss/cr
'72 dt2
'77cb550k frankenberry:  '77cb550k frame, '78cb550k engine, '78cb550f tank, unknown front-end
« Reply #2 on: December 25, 2007, 05:59:01 pm »
Cracks in the diaphragm WILL leak. The diaphragm is there to allow the fluid the expand and contract with temperature and allow for changes in reservoir volume.  The cap itself is vented to the atmosphere to allow the diaphragm to move. The cap only applies pressure to the diaphragm around the periphery for a seal.  That is the cap's only responsibility for fluid containment.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #3 on: December 25, 2007, 06:40:47 pm »
There should also be a nylon washer-like part, Honda calls it the diaphram plate. This fits between the cap itself and the rubber diaphram. I'm guessing it prevent crimping the diaphram lip as you tighten the cap. Without it, crimps form which could also cause leaks.
« Reply #4 on: December 25, 2007, 09:35:09 pm »
Thanks everybody.  I will place an order for a new diaphragm tomorrow morning!  Brakes are not dragging, so I doubt that the system is running too hot -- it seems to be most closely tied to engine rpm, and vibration, so I think that the fluid must be seeping through the cracks in the diaphragm and around the circumference of cap.
Offline Jay B
« Reply #5 on: December 26, 2007, 11:00:16 am »
TT- I beleive the diaphram is also there to separate the fluid from the atmosphere, reducing or eliminating moisture in the fluid from humidity.
Jay
'77 CB550K
'74 CB350F cafe
2001 Road King
'73 CB175
« Reply #6 on: December 26, 2007, 02:07:38 pm »
Of course.  But, a simple gasket would do that.  A diaphragm is needed for the reasons stated.
BTW, the membrane isn't a total isolation.  Research osmosis.  Water can still enter the reservior, albeit slowly.
