Author Topic: CB750K0 6mm Head Bolts In Tightening Sequence  (Read 2596 times)
Offline markb
  • When I finish my current project I might be a
« on: December 28, 2007, 07:15:18 AM »
I'm putting the top end back on my motor this weekend and I have a question.  It's obvious in all my manuals what the sequence for the 8mm nuts is but when do you tighten the 6mm bolts (the four under the sealing rubbers and the other outside one), before or after the nuts?
Thanks,
Mark
1969 CB750 sandcast #97 restored - Sold Restoration thread link
1969 CB750 sandcaxt #576 - Sold
1969 CB750 sandcast #1553 - Sold
1969 CB750 sandcast #1990 - Sold
1969 CB750 sandcast #5383 restored - Sold Restoration thread link
1970 CB750 K0 restored - Sold
2010 H-D Tri Glide Ultra Classic (Huh?)
Re: CB750K0 6mm Head Bolts In Tightening Sequence
« Reply #1 on: December 28, 2007, 08:48:55 AM »
After
Offline markb
« Reply #2 on: December 28, 2007, 10:12:00 AM »
Thanks, that makes sense because after the 8mm nuts compress the head gasket the bolts will get loose.  I just feel better with a 2nd opinion and a chance to think about it.
Offline danfr
    • Apollo Motorcycles
« Reply #3 on: March 24, 2012, 12:34:01 PM »
I have both the Hondaman book and the Honda maual. I cannot find the torque specs anywhere for the 6mm head bolts! Anyone?
Apollo Motorcycles
71 Commando
74 CB750K
74 CB350F
« Reply #4 on: March 24, 2012, 01:23:46 PM »
Thanks,
Mark
My opinion is that you tighten them down centers first then the outside. This will settle the head into gasket and into the dowels. Center first then you roll the wrinkles out to the outside, figuratively speaking. Then you go for the head nuts.
After that yes the 6mm will be loose again. at this point they are useless and may be removed. (Did I say that?)
Tighten them down to something reasonable, 8 ft lbs or so, just so they won't back out and rattle.
Foir those who may be reading this and care, I'll mention a semi related point. When you want to disassemble the head, REMOVE THESE FIRST. If you loosen the head nuts first, the head will relax into the 6mm bolts and the effort needed to remove them will skyrocket and one will often destroy them getting them out.
« Last Edit: March 24, 2012, 01:26:13 PM by MCRider »
Offline danfr
« Reply #5 on: March 25, 2012, 01:15:21 AM »
Hey, thanks for the reply. I already had the 16 head nuts torqued down and tightened the described bolts tightened to a mear 8ftlbs. Thanks for your help!
Apollo Motorcycles
71 Commando
74 CB750K
74 CB350F
Offline mycb750k6
  • "res ipsa loquitur"
  • Rocketman
    • photobucket albums
« Reply #6 on: March 25, 2012, 08:29:40 AM »
I recently helped a guy put his 78F head on and his shop manual had a head bolt torque sequence quite different from the early Ks that included the 6mms in the sequence. That's also the motor that has the weird copper washers in the 8mm mix. On the Ks they are just done last after the 8s are tight.
