Author Topic: 750 engine stand idears?  (Read 10432 times)
Offline chippyfive50
  • NO PEE ON TEPEE
    • thesweetimpala
« on: December 30, 2007, 08:46:30 AM »
Anyone have a home made engine stand idea for the 750 / pics??  .
cheers!
SOHC Member#4000
71' 500K0 #1021237--E1108327
78' 550
72' 750K2(sold to "Craig")
74' 750K4 #2306334--E2303422
73' CL175
http://gallery.sohc4.net/main.php?g2_itemId=14013
Offline RRRToolSolutions
  • I love old Japanese bikes!
Re: 750 engine stand idears?
« Reply #1 on: December 30, 2007, 08:56:54 AM »
Harbor Freight $50.
I can't remember exactly where I got mine, but the cost was low. I spent about $20 more getting these flat steel brackets made and welded to the heads of the bolts. I also had a friend make me a 90 elbow so I can go in from the top. With this stand I can turn my engine 360 degrees and by using the elbow - a full 360 in the other direction. It's on wheels, it's made for a 1,000 pound big-block, and it's cheap. I will add that I like the 4 wheel version better than the 3 - more stable. The Honda photo at the bottom is with the 90 elbow.
These brackets/bolts mod allow me to hook up almost any engine safely and secure. I'll use it to wash/clean and then re-assemble. The fist detailed photo is a Kaw triple 750cc 2-stroke and the second is the CB750. I use threaded (readi-rod) and wahsers/nuts to fit any engine mount.
Gordon
« Last Edit: December 30, 2007, 09:00:24 AM by Ilbikes »
Kaws, Hondas, Yamahas, and Suzukis - especially Kaws
  • NO PEE ON TEPEE
    • thesweetimpala
« Reply #2 on: December 30, 2007, 09:16:25 AM »
HELL YES!! Exactly. :o :o
THANKS> on my way to get one.
SOHC Member#4000
78' 550
73' CL175
Offline Patrick
« Reply #3 on: December 30, 2007, 09:18:51 AM »
They're on sale right now for $39.....
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline 1080
« Reply #4 on: January 01, 2008, 06:08:03 PM »
Here's 754's Engine stand. Sorry if photo does not post. My 2nd post 1080.
Offline 1080
« Reply #5 on: January 01, 2008, 06:11:39 PM »
More photos.
« Reply #6 on: January 01, 2008, 06:29:40 PM »
This stand started out as a TV camera dolly.. soft rubber ball bearing wheels that roll silently and can be used on carpet! wheels can be locked or allowed to swivel 360 degrees.
 Now that is a stand.. guys!
Offline jalfonso
« Reply #7 on: January 02, 2008, 06:56:40 AM »
Gordon,
Would you please post a picture of the 90 degree bracket.  Also, would your friend consider making another one.  Your version looks good and is easier on the wallet than others I've seen.
Thanks,
John
John Alfonso
1974 CB550 Four
1982 750F Super Sport
Offline jevfro
  • 1975 CB750 K5
« Reply #8 on: January 02, 2008, 11:41:56 AM »
Who made that killer stand?  it's sweet...  That's a nice looking motor too, iis that a turbo? or is that some other fuel injection/mag setup?
 I would love to find a junked frame and just cut off the top off of it.  I saw someone w/ a "test rig" setup like that on a youtube clip somewhere on the forums.  I've seen some pretty wimpy looking stands at a cummings tool sale recently.  I was tempted because the price was really cheap ($40-60), but so was the construction (thin tubing, sloppy fitting/wobbly. If you're just cleaning it and need something to hold it and allow access they would have worked.  However, I wouldn't have trusted it to hold steady while wrenching on it.  The first one in this thread looks much stronger than the cummings versions, and I like those 90* extensions too, very smart!
« Reply #9 on: January 02, 2008, 09:07:38 PM »
jevfro,
I built that in 87 i think..only used it for display so far.. but a buddy had it for about 10 years!!
it rotates 360 degrees with pinch clamp to hold any position, base also swivels so that motor can be over a leg or between the legs. Holding the top case half is a bit tricky, got to work on that a bit.
I made it so the whole stand assembly can pull out and I can make another attachment for other engine for assembly or display.. once the wheels are pointed the way you are going, you can push it with ONE FINGER with a whole engine on it on a concrete floor!.. and it will not mark a hardwood or carpet floor.
Offline rbmgf7
  • 2>4
« Reply #10 on: January 03, 2008, 01:17:04 PM »
just made these this morning
materials:
2X4X10 made two stands; had a piece laying around
harbor freight castors; $6
screws; had some already but i don't think they're too expensive
the only tools i used was a mitre saw and powerdrill. it's made to cradle parallel to the two engine mounts.
i have the one on casters to roll that spare K engine around for now. the other stand will be used on the benchtop while reassembling the F2 engine. in all, bout $10 to make two.
Offline chrislib
« Reply #11 on: January 03, 2008, 04:33:31 PM »
I don`t have anything constructive to say about engine stands , but I laff my keister off every time I read the subject line....idears..LOL! FWIW all stand IDEARS posted hears are nifty, nice work gents!
Chris...closet Idlefiddler
#1975
1973 CB750K...CANDY BACCHUS OLIVE
« Reply #12 on: January 03, 2008, 07:11:20 PM »
John, I don't mind taking a photo and posting - you just have to wait until it returns. My son borrowed it for his hunting trip.
Regards,
Gordon
Offline mark
« Reply #13 on: January 07, 2008, 02:11:25 PM »
Found this transmission stand at a yard sale for $25 and it had to come home. It came with several adapters, including the contraption pictured below - intended for Chrysler TorqueFlite.
I reckon that I can put together some bolts, spacers, washers, angle iron bits, and such - to where I can stick the TF adapter to a Honda engine without it getting in the way of anything important.
Them's my idears. I may upgrade the wheels when I get some better carpet. ;)
Happy trails.
F you mark...... F you.
« Reply #14 on: January 07, 2008, 03:49:04 PM »
The only problem that I have with the converted car engine stands is that you still need to somehow get your engine up in the air and hold it there until you can bolt the sucker into the stand, so you need a couple of strong men, or an engine lift, or a "chain hoist" to get it there, and when you do, it's fixed at one height that might not suit you ergonomically, depending on how tall you are, and whether you like to work on your engine standing up or sitting down, etc.
The company I used to work for bought this hydraulic scissor action trolley to make it easier for us to move .50 cal machine guns from APC's in and out of the armoury at work, but I could see that it was much more valuable to me in my garage, so I "borrowed" it, and I've found it to be probably one of my most useful garage tools. Eventually I'll put smaller castors on it, but for the time being I can raise my bikes an extra couple of inches by sitting the center stand on a length of 2 x 4 so that I can slide a 750 engine straight out of the frame onto the trolley, then I just push it into where I want to work on it, and jack it up to the desired height, for when I want to stand up, or sit down. Once I've done the work, I just roll the trolley over to the bike, and slide the repaired engine back in.
I place the engine on a cardboard sheet which allows it to easily swivel around to where I want it, and just prop the engine up on a couple of blocks of wood, and I can easily strip the engine down from "still in the bike" to the bare cases, all by myself, with no outside help. If I need to swivel the engine upside down I can use the trolley to move the engine over to an engine stand to hook it up, but I have to admit that I haven't needed to do this yet, as the only thing I've needed to do underneath the engine is remove the sump plate, oil pump, and all the lower engine bolts, which I can do on the trolley just by rolling it forward. (750 engines are "front heavy" so naturally want to roll forward anyway) This trolley cost the company $1000.00 when they bought it, but you can pick up a chinese version for a couple of hundred bucks. It's rated to 500 KG (1100 pounds) so with slightly smaller castors fitted, you could also use it as a bike lift. Cheers, Terry. ;D
fuzzybutt
« Reply #15 on: January 07, 2008, 11:18:58 PM »
i have a crashed frame out in the back yard, i light have to go and cut it up and have a test stand.
Offline DarkRider
« Reply #16 on: January 08, 2008, 12:37:27 AM »
what did your company say when you "borrowed" this trolley?
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
Offline 750essess
  • Orleans Cycle Repair & Resto
« Reply #17 on: January 08, 2008, 07:15:25 AM »
Heres what I made for a stand. You can bolt the cradle to the engine on the floor then lift it up and slide it into a standard car engine stand.
Allows you to rotate engine 360 degrees. Also you can assemble the bottom end by flipping the top case over and laying on the cradle to install the crank and trans.
Orleans Cycle Repair and Restoration
76CB750F
69Z50
XR650L
« Reply #18 on: January 08, 2008, 04:24:52 PM »
Well not much mate, they lost the contract so I returned it, but when they cleared all their company owned stuff out they left it behind, so as the new company was buying all new "Material Handling Equipment" anyway, I took it back home.
I felt a little guilty until I discovered that they took away, and sold, a Defence Department owned fork lift truck, so after that I wasn't too fussed, ha ha! Cheers, Terry. ;D
Offline Gamma
  • Bike Magazine august 1980 page 71. me on my F1
Offline KB02
« Reply #20 on: February 24, 2008, 06:25:01 AM »
I finally got a good picture of the engine stand that I build for my engines. This is actually the third engine that's been on this stand (two SOHC 750's and 550 Kawi).
One change that I made with putting the last engine on is to use plain rods, and not threaded rods.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline Tower
  • Only at conception could I have been called a
  • My personal time machine: 1973 CB750K3
« Reply #21 on: February 24, 2008, 01:11:08 PM »
@Gamma, now that's using your head.  It must be fairly easy to tilt up for access to oil pan.  How thick is that alloy?  Can' t be too thin, otherwise it would crease the table.  Care to post some measurements?
Add this to @gearbot's 2x4 dolly idea and its a masterfull mobile combo for next to no cost.
The only thing better...might be getting a free $1000 hydraulic scissor dolly ;)
« Last Edit: February 24, 2008, 01:14:37 PM by Tower »
« Reply #22 on: February 24, 2008, 03:33:32 PM »
"The best things in life are free"....................  ;D
Offline mrblasty
  • Expertly
« Reply #23 on: February 24, 2008, 06:37:16 PM »
Terry, I've been eye balling that same set-up for sometime at the chinese tool importer.
Looks mucho handy
I farted and made my son cry.
1973 Honda CB 750
1975 GL 1000
« Reply #24 on: February 25, 2008, 11:06:02 PM »
Yeah, it's a great bit of kit mate, and those Chinese ones are pretty affordable. The thing I like about it over any other ones that I've seen so far is that you don't have to lift your engine and carry it anywhere, so you can do it on your own without injuring yourself.
You can use it as a workbench (I do) or you can use it to raise the engine to the same level as your workbench if you want to, same as you can raise it up to attach it to an engine stand, if you have to. If I didn't get that one for free, I'd probably buy one myself! Cheers, Terry. ;D
