Author Topic: bolt on steering damper?  (Read 2115 times)
Offline jaguar
« on: January 03, 2008, 07:40:39 PM »
anyone know where i can find a bolt on damper for a 76 CB750f?
if not what did you use?  will the small units from modern superbikes work?  how do you know if the unit will have enough travel?
Offline cb350twin
    • http://mail.google.com/a/sohc4.net/
Re: bolt on steering damper?
« Reply #1 on: January 04, 2008, 01:46:44 AM »
Here's a  good post http://forums.sohc4.net/index.php?topic=10547.0
Partsnmore used to have good adjustable dampners for Kawi H1s H2s that fit our bikes. But they been out of stock for over a year now. >:( You can also use the OEM ones from sport bikes that are non adjustable and cheaper on ebay.
1975 CB 750 K5
1972 CB 350 Twin K4
1972 CB 500 Four K1
Offline jaguar
« Reply #2 on: January 04, 2008, 02:50:39 PM »
i searched here and saw that post.
everything is either out of stock or no longer made
Offline mkramer1121
« Reply #3 on: January 04, 2008, 03:10:23 PM »
speedmotoco on ebay has them, 7 way adjustable, new for $70.  You then need to buy brackets to mount it.
« Reply #4 on: January 04, 2008, 04:59:22 PM »
There's no "bolt on" kits around anymore, mounting the "ram" end of the damper is no problem with most CB750's as there is a threaded hole in the lower triple for that purpose, but mounting options on the frame are more difficult. You either fab up a bracket and weld it to the frame (best option) or use a horribly ugly exhaust clamp to clamp a bracket to the frame. Cheers, Terry. ;D
Offline olds-cool
  • Choppa Guy
  • Choppa
« Reply #6 on: January 04, 2008, 10:07:36 PM »
Nice seaweb.  I would think that would do it.  $49 isn't bad for the damper either.
