Author Topic: Quick Q: Measurements of Honda 350F  (Read 739 times)
Offline loonymoon
    • Loonymoon's CB350F enthusiasts gallery
« on: January 05, 2008, 09:38:45 AM »
I'm looking at possible sheds to house my bike, and not having it here I can't measure it. Can someone give me a length tip of front wheel to tail (bearing in mind that mine has a rack so possibly adding a couple of cm).
Also measurements across the handlebars (standard ones) would be helpful, as would a guesstimate of the width of the bike at the bottom of the exhaust pipes/engine and the height from the floor (as I would  have to get it through a door way where there is a drain with a high drain surround partially blocking)
Thanks for your help guys!
okie
Re: Quick Q: Measurements of Honda 350F
« Reply #1 on: January 05, 2008, 11:08:02 AM »
From the original Honda Owner's Manual:
Overall Length:  81.1 inches(2060mm)
Overall Width:  30.7 inches(780mm)
Overall Height:  42.9 inches(1090mm)
Wheel Base:  53.3 inches(1355mm)
From my own measurement:
Ground clearance:  7.5 inches(190)mm  That is to the bottom of the oil drain plug.
Keep in mind that all of these measurements are for the beautiful red CB350F.  The green ones may be different. ;) ;)
Offline loonymoon
« Reply #2 on: January 05, 2008, 11:16:22 AM »
Many thanks Okie. That's a great help.  ;D
