Author Topic: VIN plate removal on a K1 frame  (Read 3396 times)
Offline GNXFan
« on: January 10, 2008, 05:51:41 PM »
I am prepping my K1 frame for powdercoating and have come to the removal of the serial number plate. Does anyone here have any cool tips on getting the pins out without destroying the aluminum plate? I usually push the pins out from the inside of the head of the frame but that doesn't work on a 750 because the metal is thicker and the pins aren't exposed on the inside. I have done a search and didn't find anything.
« Last Edit: January 11, 2008, 07:21:15 AM by GNXFan »
newcbguy
Re: VIN plate removal on a K1 frame
« Reply #1 on: January 11, 2008, 04:29:20 AM »
this is one of the reasons that I painted my frame. I just masked the vin plate off blasted the frame then painted. I have to admit that I have had to touch it up several times though.  :-\ I would imagine that you would have to drill the factory rivets and reattach with a rivet gun, but the rivets wont be the same.
Offline markb
  • When I finish my current project I might be a
« Reply #2 on: January 11, 2008, 05:56:00 AM »
The plate is held on with a type U drive screw.  Its kind of like a round head screw with no slot and a steep pitch thread that is tapped in with a hammer.  I replaced mine on a K0 with a 1/4" long #2.  First use a center punch to put a dent exactly in the center of the head.  Then carefully use a #44 drill (.086) to drill until the head falls off.  You will probably have to use a small punch to push the remaining shank through.  There was some adhesive under my plate so I gradually worked my way around the plate with a razor blade to cut it loose.  The screws are a McMaster-Carr part #90081A077 and they were about $3 for a box of 100.  I used the zinc plated but I think they're also available in stainless.
Mark
1969 CB750 sandcast #97 restored - Sold Restoration thread link
1969 CB750 sandcaxt #576 - Sold
1969 CB750 sandcast #1553 - Sold
1969 CB750 sandcast #1990 - Sold
1969 CB750 sandcast #5383 restored - Sold Restoration thread link
1970 CB750 K0 restored - Sold
2010 H-D Tri Glide Ultra Classic (Huh?)
Offline GNXFan
« Reply #3 on: January 11, 2008, 07:23:57 AM »
Thanks for the tips. I had thought about drilling the screws out but I didn't think anything else was available to replace them. I have already worked a razor blade behind the plate to loosen up the glue as well as spray some WD40 as well.
Offline myhondas
  • Not really such a
« Reply #4 on: June 29, 2009, 07:31:21 PM »
these are called drive screws.. you can get them at a lot of shops and hardware stores. Reason for the concave punches is to keep the round head with the center punch hole intact. Plastic mallet will work most of the time also.
http://www.hansonrivet.com/w58.htm
1974 CB 750 K4 SHOWROOM
1965 C100 CUB 50 (PIT BIKE)
1996 VF 750 CD daily rider
SOHC# 5105 11228
