Author Topic: Wiring question  (Read 1333 times)
Offline James
Wiring question
« on: January 14, 2008, 02:32:14 AM »
Hi,
I'm just finishing reinstalling the wiring on my 550, I've got the Clymer manual and the haynes manual, and had a look on the usual online diagrams - however these show the US models of wiring and I'm having a problem with a UK bike.
The problem is I have a Brown/Blue wire from both switchgear and one from the fuse box (i think It was dark when I was finishing off last night), can anyone provide a clue to where these three connect?
The only diagram that is close is the CB350, but that shows one brown/blue from the RH switchgear, none from the left.
Does anyone have a UK diagram for a 550?
Thanks.
J.
Gort, Klatuu Baratta Nic-DOH!
Offline lostinthe202
  • Quality testing Elite 80's since 1978!
Re: Wiring question
« Reply #1 on: January 14, 2008, 04:22:16 AM »
I don't know UK bikes at all, but if you've got the same color line coming from both sides that should give you a pretty good idea what it's used for, what's the commonality between the two sides?  Again I don't know about UK bikes so I can't tell you anything specifically except to say that usually whatever color the line is is plugged into the same color.  When I replaced the harness in my 550k I just matched colors and everything worked fine.
Good Luck!
'72 CB500
Offline Bob Wessner
  • "Carbs Suck!"
Re: Wiring question
« Reply #2 on: January 14, 2008, 05:24:56 AM »
I have a manual on CD that includes the wiring diagrams and one is labeled "Europe Type." I can try to print/scan and send it if you are interested. Oh, it is also for the K3 model 500/550 also.
« Last Edit: January 14, 2008, 05:26:43 AM by Bob Wessner »
Re: Wiring question
« Reply #3 on: January 14, 2008, 07:13:00 AM »
I am in UK and have all the books BUT i need to know exactly which model/year it is as they are all different slightly
Online SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
Re: Wiring question
« Reply #4 on: January 14, 2008, 07:14:11 AM »
The only common wire to both sets of switchgear is the green which is the common and goes to the frame (eventually)
As lost says, remember the main colours:
Red: battery
Black: switched 12V
Green: common
and then make sure that all coloured wires are connected to similar colours.
Where this falls down is if you have parts fitted from a different model - I don't have a 550 manual (sold it with my K3).
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
Offline James
Re: Wiring question
« Reply #5 on: January 15, 2008, 01:43:09 AM »
Thanks for offers everyone, I had another look last night and I've managed to decipher what it was, there is a brown/blue coming from the fusebox, which goes to the brown blue on the right hand switchgear, according to the clymer and haynes this should be brown/red, this is the bit that was confusing me. (or I may just be colour blind)
On the left hand switchgear there is another brown/blue which turns out to be the turn signal buzzer.
Thanks again
