Author Topic: front chain sprocket wiggle?  (Read 1570 times)
Offline mustangcar
« on: January 14, 2008, 08:42:58 AM »
the sprocket is a 15 tooth on a 630 chain,it has about a 1/8 freeplay wiggle to it,is that normal or should it have none? It only has one center bolt that i see on the sprocket,on the service manuals there is two bolts on the front sprocket,was that a change for that year?,my bike is a 78 750k,,thanks
Offline City Boy
Re: front chain sprocket wiggle?
« Reply #1 on: January 14, 2008, 09:44:23 AM »
Sprocket wiggle back and forth on shaft is OK.Two bolt mount is earlier method,it also allowed some movement of sprocket on shaft.What you do not want is play  between splines of sprocket and shaft.
'52 Kiekhaefer Mercury Rocket Hurricane KG4H
'70 750/RC 1000 Original Owner
'83 1100F
Offline mustangcar
« Reply #2 on: January 14, 2008, 10:07:41 AM »
thanks,the freeplay is outward away from the motor,tilts very lightly.should i tighten the bolt clockwise?maybe its missing a washer/spacer
« Last Edit: January 14, 2008, 10:09:59 AM by mustangcar »
Offline dpen
« Reply #3 on: January 14, 2008, 10:22:29 AM »
Don't worry about it
Mine is a '78 too & that had me worried a few years ago
I checked into it extensively & that is the normal setup i.e. a bit of lateral movement
Put a drop of locktite on the bolt to be sure & ride on
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #4 on: January 14, 2008, 11:48:45 AM »
I always 'thought' the lateral play was to accommodate/follow some lateral chain movement. Without it, if the sprocket were fixed, with no movement, I would think there would be excessive side plate and sprocket tooth wear. I could be wrong though, it's been known to happen, just ask my wife. ;)
Offline Bido
« Reply #5 on: January 14, 2008, 02:52:35 PM »
I had the same play on my 78 SS after some research found that it is normal.
Bido
1978 CB750 Supersport F3
1981 CB750 K
