Author Topic: What is all required for the dual disk swap for the 550?  (Read 5840 times)
Offline DarkRider
« on: January 15, 2008, 06:32:12 AM »
Well i have done a couple searches trying to find more info on doing a dual disk swap to the front of my 550 but cant seem to find anything that really gives clear details...i see the odd reference here and there..maybe im not using the correct search terms...Anyways...What is all required to do a dual disk swap on this thing? The main area im wondering about is the front hub...Do i reuse the stock hub or am i searching for a different hub? I know that im going to need a T fitting for the brake lines as well as a new Master cyl since the stock single disk brake one is not strong enough..but i was planning on using a master cyl from an Aprilla sport bike anyways because of said dual disks...What all do i need and what donors do i get the needed parts from?
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
Re: What is all required for the dual disk swap for the 550?
« Reply #1 on: January 15, 2008, 06:40:58 AM »
sent you an email
Offline DarkRider
« Reply #2 on: January 15, 2008, 07:14:52 AM »
sent you an email
Woot!!! Thanks man! Thats the info i was looking for. Twin Disks here i come!!
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
Offline A Grove
  • Some people call me a
« Reply #3 on: August 13, 2008, 08:37:56 PM »
this is real old i know.. but can you elaborate on what he told you?  I am very intersted in this.
Offline bradweingartner
  • 74 CB 550 x2
« Reply #4 on: August 13, 2008, 09:22:22 PM »
Most importantly you need the front fork that has the mirrored ears and bosses for the caliper.
And you need a complete brake assembly just like the one on your left hand fork. And a duplicate rotor.
Then you need longer bolts to go through the hub and hold both rotors on. And then you need the appropriate small diameter speedo housing to retain the speedo. Other than that, basically a bolt on, no problem swap.
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #5 on: August 13, 2008, 10:53:18 PM »
here's a visual:
longer rotor mounting bolts, a little cutting on the tach drive mount, and a second of everything on the left side and you're in business.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline FLo
  • Cafe Noob
« Reply #6 on: August 13, 2008, 10:56:29 PM »
Maybe this doc will prove usefull
Offline Jim F
  • go baby go
« Reply #7 on: August 14, 2008, 12:05:32 PM »
Or if you want to go all out then heres a project for ya
GL 1000 front end. (Not sure that would fit)
RC 51 rotors
ZX6 Six pot calipers
titanium hangers
But I just like to be a little different
Big-Jim
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
Offline JS550
  • the artist formerly known as
  • IAFF local 1307
« Reply #8 on: August 14, 2008, 04:00:46 PM »
Can I get that email too? Im am getting a parts 550 next week & if I can swap to dual disc easy I will.
If you're worried about how many calories are in beer, is losing weight really your biggest problem?
Offline unkle fester
« Reply #9 on: August 14, 2008, 04:39:01 PM »
what are the caliper hangers off of???????
Offline paulages
  • 1976 cb735
« Reply #10 on: August 14, 2008, 04:54:31 PM »
a cb550
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
« Reply #11 on: August 14, 2008, 06:11:24 PM »
the brackets between the calipers and legs are titanium and from a cb550??
  • 74 CB 550 x2
« Reply #12 on: August 14, 2008, 07:27:09 PM »
They are custom milled!
Offline I Zombie
« Reply #13 on: August 14, 2008, 07:36:56 PM »
is it the same for a 750?
lookz to be the same set up i have
78 CB750K
« Reply #14 on: August 14, 2008, 10:15:15 PM »
js550 the email is the same as the link from flo, I know cos i wrote it,-----BEFORE this damn 'puter went dyslexic
Offline paulages
  • 1976 cb735
« Reply #15 on: August 14, 2008, 11:20:25 PM »
sorry...missed a post.  ::)
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline Jim F
  • go baby go
« Reply #16 on: August 15, 2008, 11:42:06 AM »
the brackets are milled from billet titanium and the bike is a 75 K Honda 750
Offline A Grove
« Reply #17 on: February 24, 2009, 11:27:51 AM »
I didn't want to start a new thread, but I've tracked down all the necessary pieces except for a few..
I need a new MC, and hose/fittings to connect it all together.  I would like to find/run a NEW MC, but am not sure if thats possible.  As far as I know, I need a MC that with a certain bore dia. and so long as it matches (or is close) to that dia, I should have a solid set-up, yes?
And fittings/lines.  Is this something I need to sort out locally?  Or are the fittings found online somewhere, etc? thanks
Offline A Grove
« Reply #18 on: February 24, 2009, 03:47:47 PM »
Bump it uppp.
