Author Topic: Purpose of "O" ring fitted to bottom of Cylinder sleeves  (Read 1927 times)
Offline CB750F2
  • Pat's first Honda 750 F2
« on: January 17, 2008, 02:38:24 PM »
What is the purpose of the 61.8x2.0mm "O" rings fitted over the bottom of the cylinder sleeves of the CB 750s? What holds these "O" rings in place? Would it be a good idea to "cement" these in place with threebond 1104? Thanks, Pat
Regards
Pat from Australia
Offline scunny
  • don't call me expert
Re: Purpose of "O" ring fitted to bottom of Cylinder sleeves
« Reply #1 on: January 17, 2008, 07:39:06 PM »
not sure about the 750 but the 650 has a groove to sit the O-ring in.
I think(dangerous) it's to stop oil travelling up outside the sleeveand under your head gasket
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
« Reply #2 on: January 17, 2008, 08:11:41 PM »
Did Honda cement them in place??
I am sure the Honda engineers considered the job it has to do when the determined the specs for the chamfer they sit in.. pretty sure they know how to build an engine.. so do what the manual says..
Generally an o-ring provides a seal to prevent leaking.. tolerance are calculated and parts machined so that the chosen o-ring will do the job
Offline CB750F2
« Reply #3 on: January 18, 2008, 12:21:56 AM »
Ok. I am finding it difficult to seat those "O"rings properly in their seat so I am going to machine a sleeve that will fit over the sleeve to make the job easy. Thanks for your replies and help. Pat
Regards
Pat from Australia
« Reply #4 on: January 18, 2008, 08:37:45 AM »
I think assembling the moyor is what seats them..
Offline Cvillechopper
  • Is just pretending to be an
  • If not for my failures I'd never know my limits
« Reply #5 on: January 18, 2008, 09:02:34 AM »
I prefer to have them seated prior to assembly just to make sure you don't have a twist (potential leak).  those o-rings are pretty durable.  Once I have them on the sleeve, I roll them as far down as I can get them use a small, flat plastic blade on each side between the ring and the sleeve to "pry" it down.  Rotate the position of the blades and go at it a few more times and PRESTO, they're seated.  At least that's how I get it done and i've not had a leak yet.
It is the mark of an educated mind to be able to entertain a thought without accepting it.  Aristotle
Offline Big Jay
    • CBRzone
« Reply #6 on: January 18, 2008, 05:54:31 PM »
Never really understood what they were trying to prevent. When big bore sleeves are installed, there is no o'ring and no leaking.
Jay
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
« Reply #7 on: January 18, 2008, 06:04:36 PM »
it's to stop oil travelling up outside the sleeve and under your head gasket
That's what I've been told too.
Gallery at:
Bob550four
« Reply #8 on: January 18, 2008, 06:52:25 PM »
this is Honda folks.  they have a big habit of OVER engineering something like this to prevent issues as best they possibly can.
It's built like the manual says to build it because an engineer years back designed it, probably tested it 20000 ways from sunday, then tested some more to ensure it works 10000%   why change that?
