Author Topic: what would cause the front brake not to accuate the brake light?  (Read 1537 times)
smokeygold
1975 CB550 front brake works fine however, brake light won't go on whan applied! Rear brake and light work fine.
Offline merc2dogs
Re: what would cause the front brake not to accuate the brake light?
« Reply #1 on: January 18, 2008, 09:57:17 PM »
Bad switch or wire, rarely a clogged passage.
 Cross your brake wires with a short strip of wire and see if the light comes on, if they do the switch is bad, otherwise it's the wire and you have to trace it through to make sure connections are clean and tight, and that there are no breaks in the wires.
Ken.
Offline Jay B
« Reply #2 on: January 18, 2008, 09:58:50 PM »
Plugged or bad actuator on the front brake line. Mounted on the bottom triple.
Jay
'77 CB550K
'74 CB350F cafe
2001 Road King
'73 CB175
Offline Kevin D
  • SE Michigan
« Reply #3 on: January 19, 2008, 11:09:15 AM »
I had broken copper strands, hidden inside the wire jacket, behind the crimped connectors at the switch. It made for intermittent operation. I had to cut the wire back a little bit and splice in new - and very flexible - wire.
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline Hope
  • How did I become an
  • SOHC member since '01
« Reply #4 on: January 20, 2008, 07:34:48 AM »
I have the same problem, but with my rear brake.
Offline old76cr
« Reply #5 on: January 20, 2008, 08:24:41 AM »
Mine had a little corrosion at the connector at triple clamp. Unplugging it a couple of times and petroleum jelly solved the problem.
cb750 k5        76 Husqvarna 250cr                                                       77 Can-Am 175   1973 honda SL125
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #6 on: January 20, 2008, 09:19:43 AM »
In case you aren't sure where the switch is, look under and behind the headlight bucket, assuming you still have a stock configuration.  Follow your brake line until you find a large aluminum manifold.  Brake line to the front caliper exits the bottom and the switch takes up the top and exits to the rear.  Here is a (bad) picture.
« Last Edit: January 20, 2008, 09:22:11 AM by OldSchool_IsCool »
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline Tower
  • Only at conception could I have been called a
  • My personal time machine: 1973 CB750K3
« Reply #7 on: January 20, 2008, 09:23:55 AM »
Shorting across the wires, may or may not indicate a problem with the switch.  For example, it doesn't rule out a break in the wires somewhere further towards the light.
If shorting the  switch works, then it is the switch.  However, if shorting has no effect, then to be sure it is not the switch, unplug the wires and, using a continuity meter, measure the resistance across the switch ends.  Resistance should read infinite when not engaged, and zero when the brake lever is pulled.
« Last Edit: January 20, 2008, 09:26:56 AM by Tower »
Offline oldfordguy
  • A sheepdog.
« Reply #8 on: January 20, 2008, 04:19:00 PM »
if shorting the wires at the switch has no effect, then you know for a fact that the wiring between there in the light is messed up (which doesn't rule out the switch being bad also.)  If it lights the brake light, then you know it is the switch (or the connectors on the switch.)  No need for a meter if you don't have one.
Offline Tower
« Reply #9 on: January 20, 2008, 05:15:37 PM »
Like I said @oldfordguy, if shorting works (lights the tail lights), then both switch is bad and wiring is good. No further test is needed.
However, if shorting has no effect, then either: a) wiring alone is bad, or b) switch and wiring are both bad.  Like you implied, still need to test the switch.  I'm guessing you meant that to avoid using a meter, trace and repair the wiring, and if the tail light still doesn't work, one can assume the switch is bad?
