Be sure to visit the SOHC/4 Web Site for more information on Honda and the SOHC/4 Motorcycles.
Am I correct in thinking that if you use the bronze bushings, you eliminate the felt rings? Also, do you still retain the "dust cover" or does the total assembly then just consist of the pivot shaft and bronze bushings?
What about O rings Mark? or would they trap water?
Quote from: ceruzziracing on February 09, 2008, 12:32:32 PMAm I correct in thinking that if you use the bronze bushings, you eliminate the felt rings? Also, do you still retain the "dust cover" or does the total assembly then just consist of the pivot shaft and bronze bushings?For best results, the felt washers must be retained, if they were there. On the K6-later frames, the bushings were a "Top Hat" flanged design, as Honda cheapened the parts. These often freeze up with rusted pivot collars, since water finds its way easily into this seal-less design unless greasing becomes a religion. The dust caps are missing on this later design, requiring a bead of grease around the inside of the cupped washers to make a "seal" against water. Doesn't work as well. If your bike is this later design, I recommend cutting grease-spreading grooves across the bearing surfaces of the pivot collar so grease can find its way out there and make the seal: I do this on rebuilds of these types of arms.
Quote from: HondaMan on February 09, 2008, 03:59:33 PMQuote from: ceruzziracing on February 09, 2008, 12:32:32 PMAm I correct in thinking that if you use the bronze bushings, you eliminate the felt rings? Also, do you still retain the "dust cover" or does the total assembly then just consist of the pivot shaft and bronze bushings?For best results, the felt washers must be retained, if they were there. On the K6-later frames, the bushings were a "Top Hat" flanged design, as Honda cheapened the parts. These often freeze up with rusted pivot collars, since water finds its way easily into this seal-less design unless greasing becomes a religion. The dust caps are missing on this later design, requiring a bead of grease around the inside of the cupped washers to make a "seal" against water. Doesn't work as well. If your bike is this later design, I recommend cutting grease-spreading grooves across the bearing surfaces of the pivot collar so grease can find its way out there and make the seal: I do this on rebuilds of these types of arms. i removed the swingarm on my 78k removed the cupped washers ,now i see some pressed in caps that look like phenolic/plastic how do i remove them?,they seam to chip if i try to pry them off,tried to pump grease in the center grease zerk like crazy but grease won't come out at ends ???is the center collar shaft suppose to rotate? cause mine seems seized, i want to make sure its not rusty inside thanks for any replies
Thanks Hondaman,i did manage to pound out the collar last night,boy was it tough to get it out,messed up one of the outer bushing ends,will have to get the bushings out,maybe using an expanding concrete bolt then tap from opposite side, i had read some time ago these type bolts are helpful in removing bearings, i tried tapping with screwdriver but they are just too skinny to catch,was thinking about replacing them with the bronze afterrmarket from oldbikebarn.com,,,i will try to replace with earlier design someday,
