Author Topic: pulling the transmission  (Read 2401 times)
Offline CB750 SS
« on: January 21, 2008, 07:31:48 AM »
The project continues...
I've got the engine completely apart and I've got 3 questions.  I'm looking to replace the main chains and paint the bottom engine case.
How do I remove the transmission.  everything else just lifts out.  Do I need to remove the gear selection mech?
Is there a product I can buy the "eats" carbon build up? that's safe on the engine.
Can I run the cases throught the dish washer?  in prep for a light sanding then paint?
Do I need to replace the main chain tensioner?  Engine has 44K on it.
Sorry 4 questions.
Thanks, Denton
Offline CBJoe
Re: pulling the transmission
« Reply #1 on: January 22, 2008, 06:26:21 PM »
you should post this in the SOHC/4 bikes forum.... it'll get a lot more attention and recomendations.
http://forums.sohc4.net/index.php?board=2.0
Cheers.... Joe
'07 Bonneville Black
'65 CB77
'66 CM91 (C90'ish)
