Author Topic: 400f swing arm bushes  (Read 2283 times)
Offline malcolmgb
  • What am I not? an
  • The BEST 400 four by far
    • malcnet
« on: January 24, 2008, 02:54:29 PM »
I have to strip out the bushes for the arm to be powder coated, at present it has the nylon bushes with a solid steel tube inside, the tube has no rifling for the grease to travel along or hole in line with the grease nipple this seems odd.
I was hoping to rebuild with bronze bushes does anyone know where these are available from now.
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
Offline dave400
  • Super Lamb Banana
Re: 400f swing arm bushes
« Reply #1 on: January 24, 2008, 03:00:22 PM »
Got mine here Mal
http://www.four-shop.de/
Dave
Offline malcolmgb
  • What am I not? an
    • malcnet
« Reply #2 on: January 24, 2008, 03:04:14 PM »
Got mine here Mal
Dave
hi again, checked there but couldn't find them listed now. When using these bronze bushes is the arm just bolted straight in with nothing else?
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
Offline dave400
  • Super Lamb Banana
« Reply #3 on: January 24, 2008, 03:22:36 PM »
No Mal they replace the original bushes so it's the same set up but they are easier when trying to fit back in….use a G clamp or a sash clamp and one at a time.
Old photo of the ones I fitted is attached
Dave
Offline malcolmgb
  • What am I not? an
    • malcnet
« Reply #4 on: January 24, 2008, 03:32:07 PM »
so the bronze bushes replace the nylon bushes, then the steel tube is pressed in, all that is then bolted back into the frame.
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
Offline dave400
  • Super Lamb Banana
« Reply #5 on: January 24, 2008, 03:39:41 PM »
The old bushes are not nylon they are made from what I can only describe as compressed horse #$%*! Take the old ones out and you’ll see what I mean.
Dave  ;)  ;D
Offline malcolmgb
  • What am I not? an
    • malcnet
« Reply #6 on: February 17, 2008, 02:16:32 PM »
anyone know of another source for these bronze bushes, the German site link above no longer seems to speak English  :(
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
« Reply #7 on: February 17, 2008, 02:43:15 PM »
Just got new bushings in from Honda for my 350f. The old ones were than compressed horse poo material but the new ones are steel. There's a catch though, they're different than the originals in that they don't have a sholder at the end of them like in the picture of dave400's bushings. I went back and checked the online microfiche and it showed that I need an additional washer and bushing to go with the new steel bushing.
So if you go with Honda, make sure you get those three pieces per side to make the "what I assume are upgraded" bushings work.
 Matt.
Gallery at:
lentobensa
Offline malcolmgb
  • What am I not? an
    • malcnet
« Reply #9 on: February 19, 2008, 09:57:18 AM »
in view of all the negative feedback about Oldbikebarn I would prefer not to deal with them.
Any other supplier known ?
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
« Reply #10 on: February 19, 2008, 10:06:31 AM »
Have you rung DS and asked?
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
« Reply #11 on: February 19, 2008, 02:53:53 PM »
malcolmgb, I just realized last night what your meant about the grease and the bushings.....
posted in my own project thread about it:
 http://forums.sohc4.net/index.php?topic=30467.0
I drilled the shaft out to allow grease to the bushings on mine.
I'm also curious... why bronze bushings?
 Matt.
Gallery at:
Offline Triffecpa
« Reply #12 on: February 20, 2008, 07:47:57 AM »
Offline malcolmgb
  • What am I not? an
    • malcnet
« Reply #13 on: February 20, 2008, 09:20:03 AM »
 Matt.
thanks Matt, Bronze is obviously more durable, although the originals lasted 30 years, they also appear easier to fit and will not collapse like the oem ones.
Kevin sells them here:
http://www.400fourstore.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=4&Category_Code=C
Tracy
thanks Tracy, but I already looked there but couldn't see them listed.
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
Offline dave400
  • Super Lamb Banana
« Last Edit: February 20, 2008, 09:43:50 AM by dave400 »
Offline super pasty white guy
  • I'm not really a
  • 1976 750 F
« Reply #15 on: February 20, 2008, 11:24:52 AM »
I'd expect that Hondaman could do you up a real nice set...
spwg
Offline Triffecpa
« Reply #16 on: February 27, 2008, 08:49:18 PM »
Did you ever find bushings?
PartsNMore has them.
https://www.partsnmore.com/cat_index.php?model=cb400&category=chassis
Tracy
Offline mca2
« Reply #17 on: February 28, 2008, 02:19:18 AM »
Rene has them, bronze bushes:
http://nieuw.honda4.nl/lagers/52108-300-300r-5.JPG
You can email him at info@honda4.nl
And most likely David Silver has something as well.
Looking for a NOS CB400f2 tank in parakeet yellow!
