Author Topic: what does this gasket go to?  (Read 1568 times)
Offline dgilling
« on: January 24, 2008, 10:13:02 PM »
So i just ordered a gasket kit for all four carbs.  Realized that was a big waste of money and i could have gotten all of this at the local hardware store.  Anyways, what do these gaskets belong to?  I took these bad boys completely apart and don't recall ever seeing these.
<a href="http://s33.photobucket.com/albums/d91/dgilling/?action=view&current=smallgasket.jpg" target="_blank"><img src="http://i33.photobucket.com/albums/d91/dgilling/smallgasket.jpg" border="0" alt="Photobucket">[/url]
Offline dgilling
Re: what does this gasket go to?
« Reply #1 on: January 24, 2008, 10:14:39 PM »
Guess i forgot some info, its a 77 cb 750k.  the gasket in the middle is a flat one.  and i don't think the picture posted correctly so i'll do it again.
Offline dustyc
  • I don't know why anyone would call me an
  • 1977 CB750K
« Reply #2 on: January 24, 2008, 10:25:21 PM »
What are the part numbers?  Perhaps a coin included in a pic for a size reference.
1977 CB750
Offline dgilling
« Reply #3 on: January 24, 2008, 10:34:40 PM »
The middle one is about the same size as a quarter.
And it's pretty hard to understand what the part numbers are for the gaskets.  It came with one piece of paper and i don't really understand what it means.  The gasket kit part number is 16010-HB5-305 and the gaskets i'm concerned about one has a B on it the other a C and the flat gasket was just hanging out in the main bag.
Offline Raul CB750K1
« Reply #4 on: January 25, 2008, 01:43:10 AM »
The explanation is in the paper. Many o.rings and washers are interchangeable between different carbs, so what Honda did was to simply create a single reference for similar carbs, that contains all the common o-rings plus all the individual o-rings per each carb, so you just have to discard the ones that are not used in your carb. This helps to keep the number of references down at the expense of some discarded o-rings.
Don't remember exactly how the paper was, but it was like a table with the bike model in the columns, and it would tell you which o-rings applied -A, B, C etc-
I hope I have made myself clear.
Offline hymodyne
« Reply #5 on: January 25, 2008, 05:24:55 AM »
IMHO, there is no comparison between the parts you can use to rebuild your carbs that are found in the local hardware store and those in a good quality rebuild kit. Although they may appear to be identical parts, their resistance to fuel and precise dimensions are different. My first rebuild of my 500's carbs was attempted with hardware store parts and i quickly found this out, resulting in the investment in a proper kit to make things right.
hym
Offline Johnie
« Reply #6 on: January 25, 2008, 05:52:58 AM »
Without a size comparison my guess - 1 might go around the top chrome fork bolt as an oil seal?  Maybe one will fit the round covers that you take off to adjust the valves?
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline dustyc
  • 1977 CB750K
« Reply #7 on: January 25, 2008, 07:21:02 PM »
Petcock?
1977 CB750
Offline sparty
  • I just play one on TV
    • Gallery
« Reply #8 on: January 25, 2008, 07:38:22 PM »
While you may think that the Honda o-rings are too much money, they are very good, last a long time, and fit properly.  Also, you mention that the middle one is "flat".  It is flat because it is worn-out.  It was a round o-ring at one time.
Sparty
1972 CB750 K2 Cafe' Style
Offline dgilling
« Reply #9 on: January 25, 2008, 07:48:21 PM »
Well put them all back together and never saw where they went.  I got a new problem now.  When i tighten the front deckplate the choke cannot move freely.  How do i fix this?
" It is flat because it is worn-out.  It was a round o-ring at one time."
This o ring is brand new and all four of them came that way.
Offline dustyc
  • 1977 CB750K
« Reply #10 on: January 25, 2008, 08:14:56 PM »
How many of each of those do you have?  I would have guessed differently if I knew there were multiples of any of them.
1977 CB750
Offline dgilling
« Reply #11 on: January 25, 2008, 08:22:39 PM »
the 3 shown came with each kit.  meaning 12 total
