Author Topic: 1978 cb750K exhaust  (Read 2551 times)
Offline grwmotocycles
1978 cb750K exhaust
« on: January 26, 2008, 12:14:02 PM »
Checked the search for an answer but no luck.  Is there any particular  reason a 69to76 exhaust will not fit on a 78. I have been looking for a new exhaust but the guy says it is for 69-76.  Thought even with minor mod will it work?  Thanks Geno
Offline Gregorymoto
  • SOHC Aficionado
Re: 1978 cb750K exhaust
« Reply #1 on: January 26, 2008, 12:29:34 PM »
They all fit the same, i have a 78F motor on a 72 header and pip works and fits fine.
What is it that is not matching or fiting up.
You are using SOHC 750 motors right
G. Mountain
Yep, i have issues with this sort of stuff.
« Reply #2 on: January 26, 2008, 12:39:14 PM »
G. Mountain
It is a SOHC 78K model that I purchased  as a project and I am just trying to get all DUCKS in a row as I plan and continue my rebuild.  I was hoping the earlier exhaust would fit cause I found one I liked but was not sure if the 76 would fit.  Glad to hear it will work.
            Thanks Geno
Offline Gregorymoto
  • SOHC Aficionado
« Reply #3 on: January 26, 2008, 02:20:34 PM »
good luck
« Reply #4 on: January 26, 2008, 02:28:12 PM »
Only difference is early pipes fitted over spigots that bolted into the head whilst later ones diddnt have the spigot but a loose flange and half round collets on the pipe so to fit late pipes to early head remove the spigots and use later hardware
To fit early pipes to a lete head fit spigots with the early hardware.
Mounting points may or may not line up but brackets can always be made for that
