Author Topic: balancing question to Big Jay and others  (Read 2587 times)
Offline turboguzzi
« on: January 29, 2008, 01:17:32 PM »
Been a bit silent lately for the simple reason that I'm working nights to get the 500 ready for next racing season. First race is coming up on March 9. Will post on the updates to the bike as soon as I'm finished.
Among the improvements for next season, I finally managed to get hold of some very nice lightweight pistons for my CB500. They have thinner rings for less friction, semi slipper design and most important, weight a good 20 grams less than the modified stock ones I've benn using. weight is down from 160 grams to 140, 12.5% less.
Question is now if its worth the while going into crank rebalancing. In theory a four is inherently balanced (have matched the piston's weight too), but still, is it worth touching the crank webs? and if yes by how much?
Your feedback is welcome
Buona notte
TG
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
Re: balancing question to Big Jay and others
« Reply #1 on: January 29, 2008, 02:21:56 PM »
mike rieck and jay will have the answers you're looking for (i'm betting they'll argue in favor for sure), but if it's any consolation, my 650 crank was almost in perfect balance from the factory. it only required minor balancing. the stator wanted quite a bit.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
« Reply #2 on: January 29, 2008, 02:41:39 PM »
Turbo, imagine geting off a Harley and then on to a Honda, That's the diference of having your crank lightened and balanced.
Also, as there is less mass to move, you will find the pick up much quicker.
You might also find a very small increase in power as the motor don't have to work as hard spinning a heavy crank.
Sam. ;)
« Last Edit: January 29, 2008, 02:43:25 PM by SamCR750 »
Offline Big Jay
    • CBRzone
« Reply #3 on: January 29, 2008, 10:14:27 PM »
You are correct that you can change piston weights on an inline four crank without messing up the balance ( as long as all pistons weigh the same).
You would really enjoy what a ligthter crank does for your bike.
Jay
Offline sparty
  • I just play one on TV
    • Gallery
« Reply #4 on: January 30, 2008, 05:30:46 AM »
That couldn't be more true.  I will never regret my APE crank.
Turbo,  You should get a lightened and balanced crank.
Sparty
1972 CB750 K2 Cafe' Style
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #5 on: January 30, 2008, 08:23:40 AM »
Turbo
What pistons did you finally find?
What is the bore of these pistons too?
I found some interesting 59mm forged pistons for Honda's GY6 engine, but can't find any other specs like wrist pin dia and distance to top.
Did you check those out?
Thanks
« Last Edit: January 30, 2008, 09:50:31 AM by FunJimmy »
Offline turboguzzi
« Reply #6 on: January 30, 2008, 10:26:32 AM »
Thanks for the feedback.
Will push now to get that cranklightened in the month I've got before closing the engine....
In any case, got quite alot of rotating mass off as I am not running alternator or starter so took the rotor off the crank and sprag clutch off the primary shaft. The lighter pistons should help here too I guess.
Fun Jimmy,
i wish i could run 59's but I am limited to 57mm max as I run in the 500 class, that's 500cc +3.5% displacement allowance for overbores. I've got 56.5's.
Wasnt aware of that GY6, what is the original bore in those?
Got a link to those 59's?
Cheers
TG
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #7 on: January 30, 2008, 10:48:47 AM »
TG
I was just searching feebay for 59mm pistons and came across the GY6 pistons that I mentioned
Here is an ebay link for some 57.4mm cast GY6 pistons.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=023&sspagename=STRK%3AMEWA%3AIT&viewitem=&item=360016714617&rd=1
And the 59mm forged pistons.
http://cgi.ebay.com/ebaymotors/Forged-Piston-kit-for-GY6-59mm-cylinder_W0QQcmdZViewItemQQcategoryZ111107QQihZ014QQitemZ330206101989QQrdZ1QQsspagenameZWD1VQQtrksidZp1638Q2em118Q2el1247
It would be nice to find some more specs on these.
Offline dusterdude
« Reply #8 on: January 30, 2008, 01:15:45 PM »
Sam. ;)
sam,did you get off on a harley?you perv. ;D
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline turboguzzi
« Reply #9 on: January 30, 2008, 02:08:49 PM »
Hi Jimmy
Thanks for the link. The 57.4 mm piston might just cut it, even if for the time being .
What makes you think that it's cast rather than forged?
Doing a short search I cam upon this
http://ginospr.com/page3.html
Irrelevant for me but you might want to give it a look.
TG
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #10 on: January 30, 2008, 02:56:18 PM »
Assumptions really.
Thanks for the link. I’ll email them and get some specs.
Those lightened pistons look a little short term.
FJ
Offline turboguzzi
« Reply #11 on: January 30, 2008, 03:36:59 PM »
Jimmy
Is yours a 550? What's the stock bore there and how big you want to go?
Might have a look at the catalogs I've gathered and see if there's something.
TG
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #12 on: January 30, 2008, 07:02:26 PM »
Yes, mine is a '77 CB550F and the stock bore is 58.5mm.
I would be interested in pistons up to 61mm maybe 62mm.
I know the 605 big bore kits use 61mm pistons.
What I'm unsure of is the max I can safely go on stock cylinders.
A little higher compression would also be nice.
Do you know the stock wright pin diameter?
Thanks for all the help.
Cheers
Jimmy
Offline turboguzzi
« Reply #13 on: January 31, 2008, 03:10:26 PM »
15mm
Bingo! my piston catalog says the Honda XL-185 is 63mm, has 15 mm pin and the compression height should give you a nice CR boost. it's 25.3 against 23.00 stock.
You could machine the piston edge to have good squish against the head and you are there.
Enjoy
TG
« Reply #14 on: January 31, 2008, 03:22:42 PM »
I think the XL185 piston is very flat topped, I ordered six for a mate who used them in a turboed Z1300 to keep the compresion down.
Just my thoughts.
Sam. ;)
Offline turboguzzi
« Reply #15 on: January 31, 2008, 03:38:58 PM »
hi sam
little 500-550 CB's combustion chamber is quite different from 750's much more tight and shallow, so do not need much bump to get the CR up. After machining the block, that is.
With the very flat topped piston in the left of pic I managed to get 12.5:1 after taking of 1,6 off the block.
TG
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #16 on: January 31, 2008, 04:33:18 PM »
Turbo
Thanks for looking that up. I'll check them out too.
Jimmy
« Reply #17 on: February 01, 2008, 06:38:03 PM »
Jimmy, I'm using 61mm pistons and the 550 sleeves are, if I remember correctly, about 0.085" thick at that bore.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #18 on: February 02, 2008, 07:31:28 AM »
bwaller
Thanks for checking into that.
I guess 61mm is about as big as I would go.
FJ
