Author Topic: sohc 750 petcock  (Read 1635 times)
Offline neil10
sohc 750 petcock
« on: January 29, 2008, 08:09:51 PM »
The brass section on petcock which connects to fuel hose fell off. I tapped it back on seems fine , just wandering what is supposed to hold it on.               Thks
Offline pddpimp
Re: sohc 750 petcock
« Reply #1 on: January 29, 2008, 08:24:45 PM »
It's just a interference (press) fit. You may want to disassemble it and JB weld it on to make sure it doesn't fall off again. Or search and get a diff. housing.
When the majority of the United States population get to be 70 years old, they will finally realize what is really important. And by then it'll be too late.
-'77 CB750 Cafe/Muscle bike (early clone)
Soon to have a hopped up 836cc *sold*
-'75 CB750 with a little bit of character
Offline Johnie
« Reply #2 on: January 30, 2008, 09:46:37 AM »
Wow, never heard of that nipple falling off before?  I would hate to have that happen while I move down the highway.  Only way I can think of those coming loose is by pulling real hard to get the fuel line off.  Maybe you can press it back in with gentle pressure and it will be OK.  That brass is soft so be careful.  You can still buy the petcock from Honda if you do not feel comfortable with your fix.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline neil10
« Reply #3 on: January 30, 2008, 12:23:31 PM »
thks all
sbc1320
« Reply #4 on: January 30, 2008, 03:00:35 PM »
Put a little loctite on it and tap it all the way back in with a screwdriver handle or the like.
« Reply #5 on: January 30, 2008, 07:19:38 PM »
Happens to me sometimes taking the tight fuel line off. No big deal it presses back in - no leaks and no danger of falling out. Petcock is new.
cheers
Andy
Offline cafe750
  • If you can't fix it with a hammer, it's electrical
« Reply #6 on: February 01, 2008, 08:51:56 AM »
It's happened to me too! I just tapped back in with a hammer and a small block of wood.
"It's an old motorcycle, the wind is supposed to blow your head around, it's supposed to leak oil, the brakes should suck, and every now and then, it should scare you so bad you piss your pants."
Roy, Washington
