Author Topic: Buffing Aluminum  (Read 20813 times)
Offline Johnie
Re: Buffing Aluminum
« Reply #50 on: January 31, 2009, 01:57:18 PM »
Joel...so I take it your fork lowers were in pretty bad condition to warrant the use of sandpaper?  My fork lowers were the easiest parts I did without the use of any sandpaper.  And I only buffed in one direction with 3 different rouges.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Joel
« Reply #51 on: January 31, 2009, 02:06:09 PM »
Yea, they're a bit rough.  They also had some adhesive reflective strips wrapped on when I got them.
Offline Really?
« Reply #52 on: January 31, 2009, 06:54:21 PM »
Keep the 220 away from the aluminum.  Unless you want gobs of sanding to get the scratches out.  If you do sand, start with a 320 or 400 wet.
Some parts I have done have not needed sanding since I started to get the hang of the rouge.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline Joel
« Reply #53 on: February 15, 2009, 02:46:49 PM »
Even with 220 wet, the casting marks are taking a long time to remove.  I spent about 3 or 4 hours last night working on them and went through half a sheet of paper.
Offline Really?
« Reply #54 on: February 15, 2009, 06:35:15 PM »
3 or 4 hours for one sheet might be stretching that sheet a bit far.  One thing that you can try is if you have a dremel and one of the sanding wheels that come with it (it slides on the rubber thing), you can lightly lay it on that area and it might go down a bit quicker.  Then bring your sand paper to it.  I believe the it a wheel that is above 200 grit.
NE550
« Reply #55 on: February 23, 2009, 07:43:57 AM »
In real rough areas I used my "Black & Decker" Mouse.  Made the job a lot easier for me.
Offline Joel
« Reply #56 on: February 23, 2009, 04:10:23 PM »
I got a couple 180 & 280 grit abrasive buffs for my Dremel that I'm going to try using on the forks.  We'll see how it works out.
http://www.dremel.com/en-us/AttachmentsAndAccessories/Pages/AttachmentsDetail.aspx?pid=511E
Offline Really?
« Reply #57 on: February 23, 2009, 06:42:42 PM »
Those abrasive buffs work but for a very short amount of time.  Not worth the amount of money spent for them for what you are using them for.  They will be knubs before you know it.
Offline BIKE
« Reply #58 on: February 24, 2009, 04:38:31 AM »
Those things go fast!  Really fast.
1975 CB750 K5
1977 CB750A
Offline Joel
« Reply #59 on: February 24, 2009, 11:03:53 AM »
That's unfortunate.  I looked for sanding drums but couldn't find anything higher than 120-grit, which I already had.  I may have to order online if these don't last long enough to finish the job.
Krixxer
« Reply #60 on: February 26, 2009, 04:58:00 AM »
hope this has not yet been posted; great link and all the info you need to make the project a success
http://www.caswellplating.com/buffs/buffman.htm
Offline papp101
« Reply #61 on: March 04, 2009, 08:35:29 PM »
I love this guy, and I love his accent.
Part 1:
Part 2:
Enjoy! Git urself a big compressor if you're using pneumatic die-grinders and such. Wear a respirator!
Offline Really?
« Reply #62 on: March 04, 2009, 10:14:16 PM »
So where do you get the 240 grit reefer?
I noticed he only went one direction on the buffer where caswell shows to go both ways.
So, is it a good idea to spin the buffer before you turn it on?
Enjoyed the video's.
Offline cxtecs
« Reply #63 on: March 05, 2009, 04:34:42 PM »
Found really good info on this on another forum I read for my other bike:
http://choppercharles.com/cs/forums/46509/ShowPost.aspx
