Author Topic: Fuel injection conversion (edit) fixed a few things  (Read 167651 times)
deuce_454
Re: Fuel injection conversion (edit) fixed a few things
« Reply #175 on: October 19, 2009, 09:42:56 PM »
retro rocket... why dont we all settle this debate once and for all.... you go out and attempt to kick start your bike, efi and all... if it works let us know  ;D
« Reply #176 on: October 19, 2009, 09:50:08 PM »
I will definitely let everyone know if it works but i will keep researching it to make sure it will otherwise i'll try a different approach.   ;)
I was just thinking, would it be possible to have some sort of primer for the injection,so when you kick it it fires enough to start the injection. I was just using the mower and it has a little diaphragm primer and it started me thinking.....
« Last Edit: October 19, 2009, 10:00:35 PM by retro rocket »
Offline Laminar
  • Retsam
« Reply #177 on: October 20, 2009, 05:56:29 AM »
The way I understand it is the diaphragm primer is used to add extra fuel to a carb, so it's irrelevant on a fuel-injected system. The Megasquirt needs the engine to turn over a couple of times so that it knows WHERE the engine is in its rotation and when exactly to inject fuel.
« Reply #178 on: October 20, 2009, 09:19:39 AM »
Yeah, primer bottle, thats how I used to start my Ducati MACH 1 .. 1 squirt, and it would start..
Offline MJL
  • Don't listen to me, I'm no
« Reply #179 on: October 20, 2009, 10:55:25 AM »
Like I said, no easy way to mount the sprag to light metal rotating element.. ;D
You are the first one to post up why it is kick only, everyone else just quotes the website. So, not knowing, I called Ken.  Then I read your post.
Interesting, as i understood it,  you just wanted to know if it worked with electric start..?
I thought it would because I didn't know that the sprag was on the alternator. Now I know better.
« Reply #180 on: October 20, 2009, 01:36:11 PM »
I'm not 100% sure but, if you want an alternator with a higher output and still retain the starter, how about the CB750A unit. I think it kicks out quite a bit more and might fit on Ks and Fs, you'll have to ask the experts though.
Sam. ;)
« Reply #181 on: October 20, 2009, 04:47:42 PM »
I understand how the microsquirt systems work, and i know what you are referring to as a primed carb but obviously we are talking injection here and i think that a series of 4 small lines going into the manifolds  would work. Priming would then squirt fuel into the manifold and be drawn in when kicking allowing the bike to fire and then the injection would take over, this seems very simple to me and i was just wondering if it would work as i see no reason why it wouldn't. Does anyone know how the injection works on modern kick only dirt bikes?
Offline MJL
« Reply #182 on: October 20, 2009, 05:53:41 PM »
Why can't you have it automatically enrich when it's cold?
I don't think that's the real issue here, if you don't spin the motor fast enough it just won't know to start.
« Reply #183 on: October 20, 2009, 06:00:50 PM »
Well you probably could, i was addressing the issue of getting the engine to spin fast enough to have the fuel injection to take over and i think priming may work, in saying that if the engine only has to spin at 50rpm to start the kick starter will achieve this no worries. The only thing that has me worried is will it turn over long enough for the injection to take over, thats why i thought priming might be the go because it will fire up the engine which should be plenty of revs to start the injection....I'm kind of asking but it seems to make sense as well.
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #184 on: October 20, 2009, 08:17:59 PM »
well you need to look no further than the newest crop of efi dirtbikes to know that you can kick start an efi motor.
Mark Twain - Notebook, 1894
« Reply #185 on: October 20, 2009, 08:39:23 PM »
How many are kick?
 My brother got a new 250 Yam  this year, it has estart, & ?kick?.. not sure..?
« Reply #186 on: October 20, 2009, 09:15:55 PM »
Gas Gas have been making fuel injected dirt bikes for 5 years and they are electric and kick start..
Offline Laminar
  • Retsam
« Reply #187 on: October 21, 2009, 11:48:27 AM »
I was assuming the MegaSquirt was also controlling ignition. If your ignition was done via points or a Dyna then your solution may work.
Offline Soos
« Reply #188 on: October 21, 2009, 01:05:11 PM »
You guys give me too much to research...
I've been thinking of going alternator, and completely re-doing the electrics.....
Multi spark ignition, and FI......
OFf to read a bit..
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
« Reply #189 on: October 21, 2009, 02:53:26 PM »
I have a Dyna ignition...
Offline 750essess
  • Orleans Cycle Repair & Resto
« Reply #190 on: October 22, 2009, 10:29:11 AM »
You can set a prime pulse on the microsquirt so if you werent running ignition it should kick start no problem as long as you get 50+ rpms to trigger the fuel ingection.
Orleans Cycle Repair and Restoration
76CB750F
69Z50
XR650L
Offline MJL
« Reply #191 on: October 22, 2009, 12:37:31 PM »
Whether MS controls ignition or not it still has to read a signal to know when to fire the injectors.
Without a knock sensor I don't see the point of having MS control ign.
Offline Joksa
« Reply #192 on: October 22, 2009, 02:13:29 PM »
Normally the injection timing is not relevant, only how often and how long per cycle.
Possibility to adjust your advance curve might be a good feature. E.g making the original advancer static and let the MS control the timing.
« Reply #193 on: October 22, 2009, 03:57:28 PM »
You can set a prime pulse on the microsquirt so if you werent running ignition it should kick start no problem as long as you get 50+ rpms to trigger the fuel injection.
Thanks Joska
Offline 750essess
« Reply #194 on: October 23, 2009, 11:15:20 AM »
The advantage to using microquirt to control ignition is can be referenced to manifold pressure instead of rpm. This is a more accurate representation of load often times than just rpm. Also it can set the timing at what ever advance u want independent of rpm, say for instance you have a turbo motor and need to retard timing at full throttle and high load or boost.
76CB750F
69Z50
XR650L
Offline Soos
« Reply #195 on: October 23, 2009, 02:48:40 PM »
:o :o :o
I never knew...... thats interesting!
l8r
-=≡ Soos ≡=-
Offline Pinhead
  • 1979 CB652-ST
« Reply #196 on: October 23, 2009, 07:38:16 PM »
Yes the Mega/Microsquirt is a very flexible piece of hardware and software. If you let it control your ignition timing you can also set up vacuum advance which is good for about 20% better fuel mileage. :)
Doug
GM HEI Ignition Conversion
Quote from: TwoTired
:D
Offline MJL
« Reply #197 on: October 23, 2009, 11:05:28 PM »
Right, and for that MS needs an rpm signal, most fuel injection computers read engine speed from the ignition.
Offline MJL
« Reply #198 on: October 23, 2009, 11:06:44 PM »
Has anyone else beside 750essess done or started a fuel injection conversion on their bike?
Offline 750essess
« Reply #199 on: October 24, 2009, 07:53:01 AM »
I tried to get started on the machining for the alt conversion, but the machinist is on vacation until tuesday. I was thinking it might be easier to have him cut out the center of the original flywheel and start with that.... you machinists out there, does that sound simpler or just retarded. I have also confirmed everything fits in the cover. Another piece will have to be made to locate the stator in the cover, am going to use the three screw locations that hold the field in.
76CB750F
69Z50
XR650L
