Author Topic: Fuel injection conversion (edit) fixed a few things  (Read 167219 times)
Offline 750essess
  • Orleans Cycle Repair & Resto
Re: Fuel injection conversion (updated)
« Reply #25 on: March 22, 2008, 11:49:12 AM »
Need to find a different rubber compund. Everything was fine until the engine got to operating temp. The engine side got softer and expanded. :(
Orleans Cycle Repair and Restoration
76CB750F
69Z50
XR650L
fuzzybutt
« Reply #26 on: March 22, 2008, 02:00:00 PM »
bummer. other than that, how did it run?
Offline 750essess
« Reply #27 on: March 22, 2008, 04:30:37 PM »
I was tweaking the idle, start and warm up settings . Had it idling pretty good and the warm up enrichment was working ok, started to lean it out so it would rev up and it quit. Thats when I noticed the manifolds went to hell.
76CB750F
69Z50
XR650L
fuzzybutt
« Reply #28 on: March 22, 2008, 06:45:09 PM »
this may sound silly as i dont know a thing about rubber and the like BUT could you melt down some good manifolds from a different bike and use that melt to make your manifolds?
Offline cben750f0
« Reply #29 on: March 22, 2008, 09:22:24 PM »
thanx for the effort M8, this is a reply so i dont miss a post...
keep up the great work..
peace
Offline 750essess
« Reply #30 on: March 23, 2008, 06:25:49 AM »
I dont know, I will look into it and see if that would work. It would probably be to hot to use silicon rubber molds. I would need metal molds. I'm looking into having some injection molded, but I figure its going to be too expensive. Could someone measure the temperature at the intake manifolds after its good and hot. These should have held up to 180 degrees, didnt figure it would get that hot there, but thats what I get for assuming. (edit) I researched melting rubber down, its not possible after the rubber is vulcanized it just burns, thats why there are used tires laying everywhere.
« Last Edit: October 01, 2009, 06:50:21 AM by 750essess »
76CB750F
69Z50
XR650L
RedMavrik
« Reply #31 on: March 27, 2008, 06:53:08 PM »
I realize I have no basis for my thinking and am entirely too late to be joining this conversation.... but....
You gotta remember that the temperature differences between a full fairing bike (possibly water cooled) and a naked bike (so to speak) such as our 30 40+ year old bikes at the intake manifold is going to be huge (relatively speaking)
I know that most rubber intakes are prone to stiffness and cracking but have you thought about composites? We have been using composite material to funnel intake air for mass production mills upwards of 200+ degrees at the motor base.
Just a thought.
Offline 750essess
« Reply #32 on: March 28, 2008, 10:08:15 AM »
I dont mind hearing different ideas. What is the composite your using? can you point me to a data sheet? I have 2 plans of attack at this time. I got a set of 02 gsxr throttles coming that have inlets and outlets that look just like a carb, so I can use some radiator hose like mentioned above. I also contacted a manufacturer of reproduction rubber parts for cars and bikes. His rubber compound is supposed to be good to 250f. Just got the sample and will do some testing on this.
76CB750F
69Z50
XR650L
Offline Buber
  • A bit of spanner spinner, but definitely not a
  • #820 on old mailing list.... :)
    • Mountain Chalets in Polands
« Reply #33 on: April 01, 2008, 01:46:13 AM »
Talking ideas... IF you have enough space - it should be easy to produce a metal flange to imitate carb body outlet, to fit the radiator hose, as well as weld, or otherwise connect this flange to the injection body, BUT would that leave enough space??
This flange doesn't need to be long, though...
Just thinking....
Welcome to my mountains!
Mountain Chalets
Offline 750essess
« Reply #34 on: April 01, 2008, 05:57:14 AM »
I considered that also, it makes it too long. Sent out my molds to be used with the new rubber compound. He wanted $125 each for him to make new molds, so we agreed he would try to use my molds first.
76CB750F
69Z50
XR650L
Offline MJL
  • Don't listen to me, I'm no
« Reply #35 on: June 15, 2008, 07:16:38 AM »
Any updates on this?
Offline 750essess
« Reply #36 on: June 16, 2008, 07:14:23 AM »
Yeah, Got a set or working manifolds now. Ended up cutting off the manifolds where they where melting and bonded the original manifold to the new ones with flexane and flexane primer. Has been working well so far. I changed to a mallory fuel pump that allowed me to mount it under the battery box. The brushes failed within about 1 hour of running??? put in a new set, been fine so far. Had problems with the alternator charging, got that fixed (wiring mistake when I made the new harness). Had problems with running ignition with the microsquirt, changed back to the dyna 2000. Bike idles well now, hot starts are good. Still working on cold starts. Have a rough fuel map in place, revs very quickly. When some time is available will finalize the tune. Haven't had time to work on it lately. I will try to get some new pics up on my site.
76CB750F
69Z50
XR650L
Offline 750essess
« Reply #37 on: June 17, 2008, 08:38:36 AM »
Heres the latest photos
« Last Edit: June 20, 2008, 12:25:37 PM by 750essess »
76CB750F
69Z50
XR650L
Offline MJL
« Reply #38 on: June 19, 2008, 01:23:12 PM »
Strange, I have to quote you to see the link to the pic.
So you have an external fuel pump, then? What is it from?
How does the airbox connect?
This is a very entertaining thread and I'd be very interested in doing this to my bike.
« Last Edit: June 19, 2008, 05:13:32 PM by MJL »
Offline KB02
« Last Edit: June 20, 2008, 04:44:38 AM by KB02 »
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
troppo
« Reply #40 on: June 20, 2008, 05:01:04 AM »
I just get sent to some spam crap site
http://www.directnicparking.com/
Offline 750essess
« Reply #41 on: June 20, 2008, 12:23:00 PM »
What the hell, I'll check into it..... Ok seems to work now. Let me know if you still cant see them. The web server must have been down and sent everything to a park page.
« Last Edit: June 20, 2008, 12:26:56 PM by 750essess »
76CB750F
69Z50
XR650L
Offline 750essess
« Reply #42 on: June 20, 2008, 12:34:24 PM »
Yes, its an external, Its a mallory 60 fi for a car. I'm finishing adapters for pod air cleaners this weekend.
76CB750F
69Z50
XR650L
Offline MJL
« Reply #43 on: June 20, 2008, 04:27:18 PM »
Please keep this thread updated. I read the thread on the DOHC board, more good info.
I've done fuel injection conversions on a couple cars, got another one or two to do, and I'd like to try it on a bike.
Offline bradweingartner
  • 74 CB 550 x2
« Reply #44 on: June 20, 2008, 04:51:50 PM »
I'll definietely be following this. Done a few megasquirt installs. B&G and I don't see eye to eye anymore on a lot of things though now and I won't be giving them any more of my money. Will be desgining my own board for the job, or possibly using the MiniMS setup. But in any case the principles remain the same! Hope you get everything ironed out!
Offline KB02
« Reply #45 on: June 21, 2008, 06:15:28 AM »
I'm still getting the parking page. weird.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Offline 750essess
« Reply #46 on: June 22, 2008, 07:34:02 AM »
Yeah, the pictures work for while, then disappear. I will host them somewhere else, also have a vid of it running I will post soon.
76CB750F
69Z50
XR650L
Offline 750essess
« Reply #47 on: June 22, 2008, 07:39:15 AM »
I had alot of issues with the dual tach ignition setup. Documentation was almost non-existant, had to read there forums for about a day before I could figure it out. The alpha-n and AN blended info is also hard to find without alot of reading on the forum. Still dont understand how this is setup completely. I have to say though once you know how it works, it works pretty well, and its cheaper than any other ECU that I know of.
76CB750F
69Z50
XR650L
Offline 750essess
« Reply #48 on: June 23, 2008, 08:38:09 AM »
here is a link to the pictures http://orleanscycle.com/Fuel%20injection.htm
and a vid of the bike running
« Last Edit: June 23, 2008, 08:48:24 AM by 750essess »
76CB750F
69Z50
XR650L
Offline fastbroshi
  • Puppet
Re: Fuel injection conversion edit (video added)
« Reply #49 on: June 23, 2008, 09:55:30 AM »
 :D  THAT is pretty effing cool!  It darn near sounds like it could be 20 years newer.  Much crisper sounding.
Just call me Timmaaaaay!!!
