Author Topic: Fuel injection conversion (edit) fixed a few things  (Read 167646 times)
Offline 750essess
  • Orleans Cycle Repair & Resto
Re: Fuel injection conversion (edit) fixed a few things
« Reply #250 on: February 15, 2010, 10:15:08 AM »
Sounds u have all the sensors u need, assuming the tbs came with a tps. U post pics by uploading them to a hosting site suck as flickr and copying and pasting the link they provide into the post between the "" that show up when u hit the image button above
Orleans Cycle Repair and Restoration
76CB750F
69Z50
XR650L
Offline lordmember1969
« Reply #251 on: February 15, 2010, 12:13:17 PM »
Thank you:)Yes tbs came with tps. Any tips about the weiring of the microsqirt? What to do or not to do ?;D  I will try uploading some pictures:)
1977 CB 750 SS Cafe
1977 CB 750 Basket case
1971 Mustang Grande
1928 Model A Pheathon Hot Rod
1977 Harley Custom FXE
http://forums.sohc4.net/index.php?topic=70333.0
« Reply #252 on: February 15, 2010, 01:49:46 PM »
That did not work  ??? ???
1977 CB 750 SS Cafe
1971 Mustang Grande
Offline 750essess
« Reply #253 on: February 16, 2010, 10:23:00 AM »
The only thing about wiring is separate the outputs from the sensor wires so u dont get any cross talk and run all grounds to same spot. Post a link to where u hosted the pics and i'll try posting them here.
76CB750F
69Z50
XR650L
Offline lone*X
« Reply #254 on: February 16, 2010, 11:42:41 AM »
Do you know the spacing between the intake on the 550? Should not be to hard to make one fit if the spacing is not far from the 750? (gsxr trottlebodies have 80-80-80) very close to the 750.. :)
Even if you can fit a set of TB's to the 550 what are you going to do for power?  If the 750 barely puts out enough current to power a full FI system, then the 550 will put out entirely too little.  Very weak charging system even when in new condition.
Lone*X  ( Don )
75 CB550K1
VTX1800C for two up cruisin.
« Reply #255 on: February 16, 2010, 01:23:27 PM »
Lone*X
I did not think off that.. sorry. :-[
750essess
Thank you for the tip:):) About the pictures..I think it is the web site that does not allow to share.. must probably find somewhere else to upload them.. or could mail them to you and if you found them interresting you could upload?
1977 CB 750 SS Cafe
1971 Mustang Grande
« Reply #256 on: February 16, 2010, 02:01:29 PM »
Here you go:) have some more grinding and painting to do before I am happy:) But it should work..
1977 CB 750 SS Cafe
1971 Mustang Grande
Offline 750essess
« Reply #257 on: February 17, 2010, 02:28:59 AM »
Looks pretty good. You had to narrow the spacing in the middle right? Get a fuel rail made and your good to go. I am using the map sensor for the suzuki also, it is much smaller than the gm unit and I have the calibration figured out if you decide to go that route.
76CB750F
69Z50
XR650L
« Reply #258 on: February 17, 2010, 11:40:28 AM »
Nope.. no modification to the tb`s or rail.. Just bolt right on... Spacing is almost perfect.. If to use on a 900f you have to modify:) Only thing is to move the throttle cable to the middle, but that was really straight forward.. You can skip that to.. but will look weird with the cable on the side? Tb`s must be mounted upside down.. but that is no problem..:)
Would love the calibration for the map sensor :):)Thank You:)
Can I use a palm computer for tuning?
« Last Edit: February 17, 2010, 11:45:35 AM by lordmember1969 »
1977 CB 750 SS Cafe
1971 Mustang Grande
Offline 750essess
« Reply #259 on: February 18, 2010, 05:12:13 AM »
Supposedly you can use palm for logging and basic tuning, never tried it. Didnt have to change spacing huh, could have swore u did. I have a set of those tbs and thought i measured them, that was about 2 years ago though. My tbs are upside down also. I will post the calibration tonight dont have the numbers with me now.
76CB750F
69Z50
XR650L
« Reply #260 on: February 18, 2010, 01:16:58 PM »
Thank you:) No did not do anything to the tbs or the rail.. Spacing is 80-80-80.. and fits almost perfect:) Can I run the microsquirt on standard ignition..? Will eventually run ignition from the microsquirt.. But will sort out the fuel injection first..
« Last Edit: February 18, 2010, 01:21:12 PM by lordmember1969 »
1977 CB 750 SS Cafe
1971 Mustang Grande
Offline 750essess
« Reply #261 on: February 18, 2010, 02:33:35 PM »
Yes u can trigger from the negative side of the coil and hook it to the opto in. Directions are in the manual, never tried it myself, have read some works great, others have problems. The cal for the suzuki map sensor (denso) is 0 at 0 volts and 140 at 5volts.
76CB750F
69Z50
XR650L
« Reply #262 on: February 18, 2010, 10:34:37 PM »
Thank you:):)
1977 CB 750 SS Cafe
1971 Mustang Grande
Offline Soos
« Reply #263 on: February 19, 2010, 04:31:43 PM »
Like the pic...
Could you take a pic of the cb750 carbs and those lined up to show the motor side of the carbs facing each other?
Fascinated by you guys doing this....
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
« Reply #264 on: February 20, 2010, 02:05:03 AM »
Will do:)
1977 CB 750 SS Cafe
1971 Mustang Grande
« Reply #265 on: February 20, 2010, 02:44:33 AM »
Here you go.. Enjoy :)
1977 CB 750 SS Cafe
1971 Mustang Grande
« Reply #266 on: February 20, 2010, 02:51:00 AM »
This is all you need to make the manifold spacers, a tube and and a flatbar. Then weld and grind :) :) ;D
1977 CB 750 SS Cafe
1971 Mustang Grande
« Reply #267 on: February 20, 2010, 03:07:47 AM »
Hi lordmember1969, can you tell me what year model Gsxr you got the throttle bodies off ?  They don't look like they need much altering at all....
750 Essess, Do you think these TB's are big enough to run on my 1000cc Engine, its way hotter than standard and i am not sure if they will supply enough fuel..
« Reply #268 on: February 20, 2010, 03:38:50 AM »
Hi..
Year 01-03.. Read somewhere they should manage 250 hp :) :) ;D
1977 CB 750 SS Cafe
1971 Mustang Grande
« Reply #269 on: February 20, 2010, 03:43:42 AM »
Hi..
Well if thats the case they should be just fine.   ;)
Thanks.
Offline MJL
  • Don't listen to me, I'm no
« Reply #270 on: February 20, 2010, 09:39:41 AM »
Hi  :)
This is a great tread... It inspired me to do an fuel injection conversion myself :):) Never got the carbs sorted out anyway.. :D Went for the gsxr throttlebodies.. Was pretty easy to install.. Have ordered the microsquirt and are waiting for it.. So wondered if i could "pick your brains" when it comes to wiring and setting up the microsquirt?? Have not decided on fuel pump yet so that is also an issue?
This is the parts I am waiting for..
2 x GM Closed Element CLT / IAT Sensor with Pigtail
2 x 3/8" NPT Aluminum Weld-On Bung for IAT or CLT
Sensor1-pigtail for the GM 3 BAT MAP SENSOR
1-GM 3- BAR MAP SENSOR
and of course the microsquirt..
Do I miss something, or is this all i need??
will appreciate any help :)
Thank you..
Why do you want a 3 bar map?  One bar is all you need unless you are using forced induction.  (One bar equals one atmosphere, aka 14.7 psi)
Offline MJL
« Reply #271 on: February 20, 2010, 09:47:00 AM »
I don't know if it's posted in this thread or not, but if you go to megasquirt.info, go to the forums there is an injector forum with a thread that lists a lot of motorcycle TBs, bore diameter, spacing, etc.
Someone help me out here, I thought I read that the 750 carb spacing is 80-100-80. Is that right?
??? Are these any good?  If 80-100-80 is right, then these would pretty much be a bolt-on.
Make/Model: GPZ1100
Year: 1981-1982
Number of Tb: 4
Inside Diameter: 34mm
Center-Center (left to right from behind): 77-97-77mm
« Last Edit: February 20, 2010, 10:20:41 AM by MJL »
Offline MJL
« Reply #272 on: February 20, 2010, 09:53:14 AM »
Ok, agreed on $400 bucks for the parts, here are the pics
starter ring gear and clutch installed on vfr800 flywheel
adapter to mount vfr800 flywheel on cb750 crank
adapter to mount stator in cb750 cover
parts installed but not bolted in
Cant get dimensions right now my digital caliper decided to quit working, got the reg/rec today too will get this put together and tested on saturday.
DI'm going backward through the thread looking for the carb spacing, and I saw the post where you have dimensions. Do you remember what the length of the taper adapter is?
« Last Edit: February 20, 2010, 10:02:42 AM by MJL »
« Reply #273 on: February 20, 2010, 10:41:27 AM »
Hi  :)
Thank you..
Have plans for a turbo, but first EFI, then ignition run from microsqirt... Then turbo :) :) :)
1977 CB 750 SS Cafe
1971 Mustang Grande
« Reply #274 on: February 20, 2010, 10:46:52 AM »
Make/Model: GPZ1100
Year: 1981-1982
Number of Tb: 4
From Carb FAQ
7A" '73(?) stock cb750 carbs: (Soos)
Type of carb                  - Mechanical linkage
depth (front to back)       -88.26mm
OD (motor side)              -36.95mm
OD (airbox side)              -40.08mm
#1&2 and 3&4 (c to c)     -76.3mm
between2&3  (c to c)      -81.5mm
http://forums.sohc4.net/index.php?topic=5410.0
1977 CB 750 SS Cafe
1971 Mustang Grande
