Author Topic: Fuel injection conversion (edit) fixed a few things  (Read 167660 times)
Offline IronicJ
Re: Fuel injection conversion (edit) fixed a few things
« Reply #300 on: March 01, 2010, 10:29:12 AM »
Have you looked at the shape of the gsxr fuel pump ? they are not that big, I guess it wouldn't be so hard to make a flange on our tanks to bolt the pump on. Plus, they are cheap, there is one for sale at 20$ on ebay right now. ( 0 bids, 4h remaining ) and there's another one for 50$ ( Buy it now ). Is it that much of a gamble to try it ? I don't think so.
« Last Edit: March 03, 2010, 01:15:57 AM by IronicJ »
« Reply #301 on: March 01, 2010, 02:36:31 PM »
Is it possible to post the links to those auctions?
Offline Laminar
  • Retsam
« Reply #302 on: March 01, 2010, 03:52:39 PM »
Searching eBay for "GSXR Fuel Pump" turned up a lot of results.
Auction 1
Auction 2
Offline lordmember1969
« Reply #303 on: March 01, 2010, 11:10:56 PM »
Hi :) Just bought one of the Sportster fuel pumps... Will let you know how that works:)
1977 CB 750 SS Cafe
1977 CB 750 Basket case
1971 Mustang Grande
1928 Model A Pheathon Hot Rod
1977 Harley Custom FXE
http://forums.sohc4.net/index.php?topic=70333.0
Offline 750essess
  • Orleans Cycle Repair & Resto
« Reply #304 on: July 23, 2010, 08:57:53 AM »
Was reading on the ms forum and saw this pic of a rotor off an 07 kawasaki ex250. The stater clutch looks a heck of alot like the cb750's. Might be easier to adapt this part.
Anybody making any progress on their EFI setups?
Orleans Cycle Repair and Restoration
76CB750F
69Z50
XR650L
Offline HavocTurbo
  • Angry little bastard of an
  • Can you tell?
« Reply #305 on: August 20, 2010, 12:19:53 PM »
Just to throw another wrench in the mix...
84-85 GPZ750 Turbos used an inline pump. There's a cheap aftermarket replacement for the crappy stock one from the auto parts stores.
Mr gasket I think? I'll have to look for the PN.
Then all you need is a return line bung on your tank and you can use ANY tank you like.
'48 HD Panhead - Exxon Valdez
'78 CB550K - Fokker CB.3
'78 Honda CB750K - Mavrik
09 XL883L - No Name
« Reply #306 on: August 20, 2010, 05:11:05 PM »
Thanks Joe and i'm glad to see you active again..... ;D
Offline Laminar
  • Retsam
« Reply #307 on: August 20, 2010, 09:20:17 PM »
What psi did they run? Current draw?
« Reply #308 on: August 21, 2010, 12:58:17 AM »
Got the wiring left, just don't seem to get there:( The Harley fuel pump got to big for my tank so i went for a in line fuelpump and adjustable regulator:)
1977 CB 750 SS Cafe
1971 Mustang Grande
Offline HavocTurbo
  • Can you tell?
« Reply #309 on: August 21, 2010, 12:09:12 PM »
I think it was like 3-12 psi .... you got me on draw. I could tell you if I found the part number.
09 XL883L - No Name
Offline HavocTurbo
  • Can you tell?
« Reply #310 on: August 21, 2010, 01:07:06 PM »
Ok... it was a walbro pump. More like 25-60 psi.
I forgot that my older pump was for carbs.
Cannot find the PN but it drew 3-3.5amps at full tilt.
You are thinking of using a regulator right?
09 XL883L - No Name
Offline dusterdude
« Reply #311 on: August 23, 2010, 04:01:01 PM »
advance auto sells a mr gasket inline pump for carbs,it has about 3-7 psi iirc.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline Laminar
  • Retsam
« Reply #312 on: August 24, 2010, 07:06:52 AM »
A pump for carbs will be insufficient for FI. You'll typically want 40+ psi.
Offline Syscrush
  • Sold. :(
« Reply #313 on: August 24, 2010, 08:03:19 AM »
I would really like to convert my 550, but have a lot of back-and-forth about if it's worth it.  Marking this thread for later voracious reading!
Offline Laminar
  • Retsam
« Reply #314 on: August 24, 2010, 08:43:30 AM »
Don't bother. Electrical system most likely can't handle it and the cost of conversion would probably exceed the value of the bike.
Offline Syscrush
  • Sold. :(
« Reply #315 on: August 26, 2010, 07:23:15 AM »
What I have planned for this bike will far exceed the value of it anyhow.  ;D
My concerns are a combination of the electrical system plus the amount of tinkering/tuning it takes to get a Microsquirt system set up correctly - plus sourcing injectors for a ~40-50hp 4-cylinder may be a problem.
The reason it appeals is because it's a nice differentiator, the parts are not a lot more expensive than a set of CR carbs, it's easier to tune in some ways (although harder in others), and for a bike that will sit for long periods between uses I think it would be less hassle than carbs.
Plus I've been interested in MS for a long time now...
Offline MasterChief750
  • Detonation
« Reply #316 on: August 26, 2010, 10:39:56 AM »
prolly just use a set of oem sport bike injectors. you set the duty cycle in the tuning you would want to find the lowest possible rating. i have a calculator for what you will need somewhere around here. here it is. its all the way at the bottom i put in 45.0psi for fuel pressure. http://www.rceng.com/technical.aspx
1976 CB750 K - Drag Bike
I AM THE STIG
Sam is THE STIG
he said i can be STIG3 tho
Offline cb550fcafe
    • KDI Cycles
« Reply #317 on: August 26, 2010, 12:18:04 PM »
I work on Onan generators often. We have a fuel injected model twin cylinder is based on Delphi electronics, they use the new GM mini pico style injectors. The motors make a small amount of HP, the bore is 80mm stroke is 65mm i.e. 653cc displacement. The injectors have a resistance greater than 12.5 ohm. They cost around $40 each. I can get more info if you need.
edit; I also have a GSXR fuel pump taken from an 01 750, I'll donate it if you want to try it.
Offline dusterdude
« Reply #318 on: August 26, 2010, 04:40:02 PM »
damnit you`re right,i didnt engage my brain before i typed.
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline HavocTurbo
  • Can you tell?
« Reply #319 on: August 27, 2010, 09:34:41 AM »
I would think an inline pump would be the easiest way. No major cutting of the stock tank (just weld in a hose bung for the return line) and you can mount it literally anywhere on the bike.
Then with a regulator mounted on the fuel rail (or off) you can change fuel pressure to suit your needs.
A lot of earlier FI bikes had them. Kawi's especially.
09 XL883L - No Name
Offline 750essess
« Reply #320 on: August 28, 2010, 10:00:38 AM »
The auto inline pumps draw to much power and flow too much. The fuel heats up and boils. The best fuel pump I have found is a Suzuki ltr450 quad fuel pump. It is readily available used and external. I am planning on using switching to this pump this winter istead of the modified internal pump I'm running now.
76CB750F
69Z50
XR650L
Offline Soos
« Reply #321 on: September 03, 2010, 07:37:45 PM »
 ;D ;D ;D
I've said it once, and will say it again.
Thanks for doing the testbed work to prove whether fuel injection will work or not on a cb!!
Seriously tempted to do that on my next big motor.
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
« Reply #322 on: September 03, 2010, 08:10:54 PM »
;D ;D ;D
l8r
I am looking forward to doing this as well, the only problem i can see is i need an already sorted system to run my engine in so i will probably use carbs for the initial run in period then switch to injection.......Lucky i have another engine that needs carbs.... ;D
Offline 750essess
« Reply #323 on: September 08, 2010, 08:45:57 AM »
You guys are welcome, been a fun and frustrating, at times, project. I have a page long list of things to change or refine for the winter such as the wiring harness, its gotten pretty messy from alterations. I still can't say I recommend anyone starting a conversion on an expensive modified engine unless u have the means to repair it if something goes wrong. Get it set up on a junker and then switch it over after.
76CB750F
69Z50
XR650L
Offline J.Webster Designs
  • www.JWebsterDesigns.com
« Reply #324 on: November 18, 2010, 06:31:52 AM »
I just scored some 01-03 GSXR 600 throttle bodies for 50 bucks shipped!!!
so what are the fuel pump specs that I am looking for?
What kind of regulator are you running?
My plan right now is to simply get everything running and sorted. I have decided to pull the bike back apart, so once i get the fuel injection sorted on it, I will tear the whole thing apart.
The throttle bodies should show up today or tomorrow!!!
I am excited! can you tell????
VISIT OUR WEBSITE!
FOLLOW US ON SOCIAL MEDIA!
Facebook:
www.facebook.com/JWebsterDesigns
Instagram:
www.instagram.com/j.websterdesigns
