Author Topic: Fuel injection conversion (edit) fixed a few things  (Read 166655 times)
Offline J.Webster Designs
  • www.JWebsterDesigns.com
Re: Fuel injection conversion (edit) fixed a few things
« Reply #325 on: November 18, 2010, 02:54:12 pm »
Look what showed up on my door step today!!!
VISIT OUR WEBSITE!
FOLLOW US ON SOCIAL MEDIA!
Facebook:
www.facebook.com/JWebsterDesigns
Instagram:
www.instagram.com/j.websterdesigns
« Reply #326 on: November 19, 2010, 12:56:18 pm »
Nice.... ;)
Offline cdoggy81
« Reply #327 on: November 22, 2010, 09:39:33 am »
Nice!
Offline Trav-i
  • Has finally become an
« Reply #328 on: November 22, 2010, 10:53:39 am »
I just thought of something.  Has anyone considered adding a Cycle X charging system.  It seems that their system put out more then stock.  Plus since your going for relialibity and cool, why not add their system to mix.  Just a though on the power problem.
Forum member #9962
1992 GL1500 Interstate
« Reply #329 on: November 22, 2010, 12:09:39 pm »
I have not decided what I am going to do about the charging system as of yet.
so far I have the throttle bodies which i picked up for $50.00 shipped
and I have an MSD external in-line fuel pump on its way for $95.00 shipped.
next up is the regulator, and Microsquirt EFI controller.
I currently have the throttle bodies apart for re-spacing and moving the throttle linkage to the center. I have already removed the electronically controlled Choke motor, butterfly's, and bearings. I am gonna pick up some JB weld later tonight and finish the removal of the e-choke system. I also need to pick up some 6mm threaded rod and some aluminum spacers.
All in all, I will be right around the cost of a pair of brand new CR carbs and will not have to deal with re-jetting and the down falls of the CR-carbs on the street like over sooting the plugs and running rich at low speeds.
VISIT OUR WEBSITE!
Facebook:
Instagram:
« Reply #330 on: November 22, 2010, 02:56:38 pm »
If you go back through this thread there is a couple of different solutions for this problem, i will be using a modded VFR alternator like the original poster..
Offline fastbroshi
  • Puppet
« Reply #331 on: November 22, 2010, 04:42:29 pm »
Hey what happened to the orleanscycle website?
Just call me Timmaaaaay!!!
« Reply #332 on: November 22, 2010, 06:49:28 pm »
so i just tried to put the original carb boots onto the throttle bodies... no luck. I tried freezing the throttle body and boiling the carb boots. It ALMOST wen on... I am going to have to find a different way of making a new carb boot because i just do not like how far the throttle bodies stick out when you make "adapters" to fit them onto the intake ports.
the cleaning and respacing is coming along nicely though!!!
VISIT OUR WEBSITE!
Facebook:
Instagram:
Offline lordmember1969
« Reply #333 on: November 23, 2010, 12:17:22 am »
the cleaning and respaceing is coming along nicely though!!!
Do you need to respace the bodies? I didn't, and they fitted almost perfect. And used the same bodies you do:) God luck :) :) :)
1977 CB 750 SS Cafe
1977 CB 750 Basket case
1971 Mustang Grande
1928 Model A Pheathon Hot Rod
1977 Harley Custom FXE
http://forums.sohc4.net/index.php?topic=70333.0
« Reply #334 on: November 23, 2010, 05:18:56 am »
I will need to re-space them as they are not correct as they are originally set up. I am also re-configuring the throttle bodies so that the throttle mechanism is in the middle instead of on the end.
VISIT OUR WEBSITE!
Facebook:
Instagram:
Offline cdoggy81
« Reply #335 on: November 23, 2010, 10:25:29 am »
If you removed some material from the inside of the original carb boots could they go onto the throttle bodies?
« Reply #336 on: November 23, 2010, 07:47:35 pm »
I am sure that I could make that work chris... but I don't really want to start tearing up the carb boots that I have just yet as they are expensive to replace from what I  remember.
Anyone have a set of "decent" carb boots laying around that they are willing to let go so I can see if i can make them work for the swap?
VISIT OUR WEBSITE!
Facebook:
Instagram:
Offline cdoggy81
« Reply #337 on: November 24, 2010, 07:07:57 pm »
crapola... I just let an old one go a few weeks ago when I sold the bike :(
« Reply #338 on: November 25, 2010, 05:54:33 am »
lol. I need to see if i can land some old ones to experiment with before I tear up a good set.
I am wondering if i start removing material if it will sacrifce the integrity of the carb boot. I dont know how prone they would be to cracking or splitting if i reduced the thickness.
VISIT OUR WEBSITE!
Facebook:
Instagram:
Offline zzpete
  • You better get an
  • 1969 CB750, 1971 CB750
« Reply #339 on: November 25, 2010, 06:16:01 am »
Did you try soaking them in wintergreen oil and xylene?
http://forums.sohc4.net/index.php?topic=76103.0
If you leave them soaking for a little longer than 24 hours they might soften up enough to get them on there. I threw a set of 1977 cb750K intakes in that were real bad. I couldn't even get the carbs on without doing something drastic. After soaking them for 30 hours the carbs slid on no problem. They even seemed a little loose at first but after a couple of days they were nice and tight. Try soaking what you have before cutting them up!
"One of the things that make motorcycling so great because it never fails to give you a feeling of freedom and adventure." - Steve McQueen
Offline 750essess
  • Orleans Cycle Repair & Resto
« Reply #340 on: November 25, 2010, 07:04:26 am »
I didnt renew the domain name on the web site. I run the regulator that came on the cbr tb's. I tried the msd 60fi pump and it didnt like being run laying flat, would loose pressure randomly. The gsxr tb's with the secondary butterfly are a little larger than the ones without I think. I have a set here they measure 44mm. Never got ahold of the older type so dont know the size on them. You could try some 77-78 f intakes they are larger on the carb side IIRC. They is a guy on the msextra forum that has developed a returnless fuel pump controller ad on board. It uses a fuel pressure sensor to control the FP, would make for a no tank modification FI setup and no regulator needed. Here is a link http://www.msextra.com/forums/viewtopic.php?f=91&t=37883&hilit=pwm+fuel+pump
PM him if interested. I drew up a slick fuel pump adapter for the internal pump, looking for someone to make it now. If I can get it made for a resonable price may go this route instead of the atv pump, it would be more compact.
« Last Edit: November 25, 2010, 07:11:59 am by 750essess »
Orleans Cycle Repair and Restoration
76CB750F
69Z50
XR650L
« Reply #341 on: November 25, 2010, 06:58:51 pm »
zzpete, The carb boots are new so they are soft. I bought then when i freshened up the bike last year.
750essess, the throttle bodies that i have measure out to 48mm OD. I found a guy that is willing to sell me some of his proprietary material that he uses on ultralight aircraft carb boots. I just have to find someone that can mold the boots that I have with a different carb side.
VISIT OUR WEBSITE!
Facebook:
Instagram:
« Reply #342 on: November 29, 2010, 02:18:48 pm »
I will take some better pictures later tonight and post what they are all about.... but you CAN make them fit into the stock carb boots.
VISIT OUR WEBSITE!
Facebook:
Instagram:
« Reply #343 on: November 29, 2010, 02:48:20 pm »
Also. I think i am going to start a new build thread for my bike as I am going to be adding quite a few "modern" items in lew of the stock '76 stuff.
VISIT OUR WEBSITE!
Facebook:
Instagram:
Offline HalfFastMoto
« Reply #344 on: November 29, 2010, 04:36:26 pm »
Nice! Like were this is headed,looking forward to your updated thread - thx
-brad
Better HalfFast than HalfA$$ed
The appropriate number of bikes is "1" more!
« Reply #345 on: November 30, 2010, 10:26:22 am »
+1 :)
1977 CB 750 SS Cafe
1971 Mustang Grande
Offline 750essess
« Reply #346 on: November 30, 2010, 11:48:33 am »
I no longer have access to mold making equipment or I would help u out. Tell me more about the proprietary material, can it withstand 350 deg?
76CB750F
69Z50
XR650L
« Reply #347 on: November 30, 2010, 01:25:51 pm »
can withstand the heat and absolutely no problems with any type of fuels. gas/alcohol, etc...  He can not tell me what his proprietary mixture is of course or he wouldnt have a job.
VISIT OUR WEBSITE!
Facebook:
Instagram:
Offline 23tbucket
« Reply #348 on: December 01, 2010, 04:58:57 pm »
How I installed Suzuki throttle bodies on my SOHC750......Go to #15, #16, #17
http://hondachopper.yuku.com/topic/24588/t/Electronic-Fuel-Injection.html?page=1
Offline 23tbucket
« Reply #349 on: December 01, 2010, 05:25:42 pm »
Here is a short video....'til I ran out of gas!!! I'm just using the auxilary tank right now for tuning. The main tank will flow into the auxillary once done.
But I ran into a BIG problem......Too much boost!! I have a rootes type of positive displacement supercharger on this fuelie (500cc per revolution and running at crankshaft speed). I was in the process of tuning...Just had the cranking, starting and idle real close...was just getting into the off-idle and mid-range when all hell broke loose!! Even at idle it was pushing a lot of air. At 5000 RPM the boost was over 20 psi, and it bent all of my throttle plates. The engine "ran away" on me.....I changed my shorts and went back to the drawing board.
I removed all of the Suzuki throttle plates and shafts. Blocked the shaft openings. All the 4 throttle bodies do now is hold the fuel injectors. I removed the supercharger air filter and built a special plenum out of fiberglass. There is a single throttle body (less the injector) on the intake side of the supercharger now. I am just in the process of retuning the ECM.
http://s258.photobucket.com/albums/hh280/23tbucket_2007/?action=view&current=001-39.mp4
