Author Topic: Fuel injection conversion (edit) fixed a few things  (Read 167215 times)
Offline wa-chiss
Re: Fuel injection conversion (edit) fixed a few things
« Reply #575 on: October 08, 2013, 10:35:32 AM »
Alright, watching the tach drive gear in the valve cover and rotating crank 2 full revolutions, I have found the tach drive gear is 2:1 Camshaft : Tach drive gear revolutions. So, a trigger wheel with 2 mising teeth 180* from each other should produce a valid cam signal. now, I just need to figure out a way to mount a trigger wheel and sensor.
Offline bjbuchanan
« Reply #576 on: October 12, 2013, 10:35:46 AM »
Look at something from an old contour I believe, 90's with an optical ignition. I haven't looked at your thread at all, though I intend to, so I don't know if this is something you have looked in to
I am linking a sight that has a ton of optical wheels and trigger setups. It is the product and support site for megasquirt ecu
http://www.diyautotune.com/catalog/trigger-wheels-c-48.html?osCsid=d57ff674dae982f4eb528a96a6b7e12b
Offline 750essess
  • Orleans Cycle Repair & Resto
« Reply #577 on: January 07, 2014, 04:45:57 AM »
I didn't get any notification of activity on this thread. I'm using a  36-1 wheel from here
http://trigger-wheels.com/store/contents/en-uk/d5.html
Haven't worked on cam sensor anymore. Working ok now with batch fire after sourcing some smaller injectors. Fought with it running badly all summer. Turned out injectors had been slowly clogging. Lol. Running good again just in time for cold weather. Try again this summer
Orleans Cycle Repair and Restoration
76CB750F
69Z50
XR650L
Offline 750essess
« Reply #578 on: January 07, 2014, 05:04:35 AM »
Also I have added a board to plug the micro module into that adds stepper idle control for the cbr600rr itbs I switched too. Not possible to run sequential now. Not enough outputs. Maybe go with ms3 pro sometime. Bought a 2013 cbr500r to actually ride while the efi 750 experiment continues. Lol
76CB750F
69Z50
XR650L
Offline sinister902
    • Anger Street Kustoms
« Reply #579 on: October 22, 2014, 08:27:00 AM »
I know this is an old thread, but I thought I would try to ask some of you guys a quick question as I'm in the process of building an EFI conversion for my cb550 with the hybrid 650/836kit engine.
you guys using the ltr450 pump......I caught where someone said it was about 50liters per hour flow rate (about 14 gallons per hour)....but what's the running psi of the pump itself before a regulator comes into play? Summit racing has all kinds of $35 electronic in-line pumps in the 18-25gph range but psi is usually somewhere in the 4-9psi range and I know these injectors should see above 40psi, Just trying to see if there's a better alternative to paying $150 for a used ltr450 pump if I can buy brand new pump and regulater for less.
« Reply #580 on: October 22, 2014, 10:08:44 AM »
I would love to see someone "produce" a turnkey EFI system for sale, even if manufactured from other parts.
« Reply #581 on: October 22, 2014, 02:48:52 PM »
I think it was Cal that told me that the R6 Yamaha, not sure which model though, has an external fuel pump, i'll be looking into this soon.... ;)
« Reply #582 on: October 22, 2014, 03:12:11 PM »
Mick,
Are you going to EFI the 750 or the 1K?
« Reply #583 on: October 22, 2014, 03:25:08 PM »
Mick,
The 1000 with the billet block will be injected.. ;)
« Reply #584 on: October 22, 2014, 05:16:05 PM »
Mick,
Eff yes!  ;D
Offline J.Webster Designs
  • www.JWebsterDesigns.com
« Reply #585 on: October 22, 2014, 06:01:24 PM »
cb750 cafe racer fan.... If there is enough interest, I would be willing to put together a turn key system.
I am already working with Ricks Motorsports to develop a charging system that will handle it. It definitely wouldn't be cheap, but it is WAY badass...
VISIT OUR WEBSITE!
FOLLOW US ON SOCIAL MEDIA!
Facebook:
www.facebook.com/JWebsterDesigns
Instagram:
www.instagram.com/j.websterdesigns
« Reply #586 on: October 22, 2014, 11:09:57 PM »
Justin, there already is a guy on the forum making a much better charging system mate, i'll find the link and post it... ;)
Here you go... ;)
http://forums.sohc4.net/index.php?topic=117735.msg1353102;topicseen#msg1353102
Offline wayfastwil@yahoo.com
    • wayfastwil
« Reply #587 on: June 11, 2016, 04:51:49 PM »
Looking at a 1975 SS 750 on ebay it looks like the one you built? Will you contact me when you have time? WIll Hoggard wayfastwil@yahoo.com
    • wayfastwil
« Reply #588 on: June 11, 2016, 07:42:50 PM »
Having issues with 1978 Honda SS750 carb boots from Vintage Cycle I'm running CR29's.  The boots don't seem to line up or seal as well as I'd like there must be something better. Anyone?? Thanks. Willl
Offline timbo750
« Reply #589 on: January 31, 2017, 09:07:05 PM »
I have just started reading this thread as it seems tho have the most amount of info about fuel injection  but all the links are now dead including the You Tube of the bike running. Has anyone got any info they could share?
« Reply #590 on: February 01, 2017, 03:07:10 AM »
Send Justin a PM Tim, {J.Webster Designs}, he's a good guy and modified my GSXR injection throttle bodies and made the cool fuel rail...
Justin, whats the news on the charging system you were working on..?
Offline dragracer
  • CB750F Dragbike
« Reply #591 on: February 02, 2017, 10:02:04 PM »
I thought this thread had been removed. Glad it got brought to life again.
« Reply #592 on: February 05, 2017, 12:20:27 PM »
Hey guys,
The charging system got put on the back burner for a bit. Business started picking up and I have been busy making cool stuff for other people. Haha! It's on the short list. The bike runs phenomenally on the fuel injection. Just doesn't last that long due to the electrical demand.
VISIT OUR WEBSITE!
Facebook:
Instagram:
Offline timbo750
« Reply #593 on: February 05, 2017, 12:43:28 PM »
Hey guys,
Thanks for the update. Are you able to give me an indication of price for both  the charging system upgrade and injection system. I really want to do this and make sure I can budget for it.
« Reply #594 on: February 05, 2017, 02:53:15 PM »
Hey guys,
Its not quite that simple Tim, the injection so far is basically injectors and you have to set the rest up yourself, there is no "kit", buy yourself a set of 2002 GSXR600 throttle bodies in the states somewhere and have them sent to Justin to be modified, thats what I did, you then have to buy the sensors, alter the harness and buy which ever system you want to run it all like, microsquirt, megasquirt, haltech, or what ever you like. My advice is to start googling and read as much as possible about aftermarket FI on motorcycles, Justin has baseline settings if you go with the system he is using, that will get you up and running, you still have to tune the system to your bike, as far as I'm aware, there are no plug and play systems anywhere....... I've found it hard here to find anyone that knows much about converting a carb bike to FI, RPE engineering in NSW do but they use Haltech and its bloody expensive, not that this is a cheap conversion anyway....
Offline timbo750
« Reply #595 on: February 05, 2017, 04:56:26 PM »
Reto, thanks. I knew it wouldn't be easy or cheap otherwise there would be more people doing it. Have you got your running right yet? And have you upgraded the charging system?
« Reply #596 on: February 05, 2017, 11:37:02 PM »
No Tim, I've got a million other things to do first, Its the last one because I'm keeping it, I grabbed the parts while Justin was working his out simply so I could get it while I could, he does good work and I knew he'd get busy real quick, as far as I know, Justins bike isn't finished either, I'm sure he'll fill in the blanks... I'm in the middle of putting my Kawasaki 750 back together, having a hard time getting into the shed ATM, its so bloody hot, even at night    :o.... ;)
« Last Edit: February 05, 2017, 11:38:34 PM by Retro Rocket »
Offline Syscrush
  • Sold. :(
« Reply #597 on: February 10, 2017, 06:48:26 AM »
When doing these EFI conversions, how much concern is there about the dia of the TB's? It seems like 2002 GSX-R600 (which made 115hp) would flow much, much more air than a ~70hp 750. I guess when you're not dependent on vacuum for the fueling system to work it just doesn't matter.
« Reply #598 on: February 10, 2017, 01:37:03 PM »
Syscrush, The TB's that I am using are 40mm. They will support plenty of power at that size. I have plans on building this motor pretty stout as Retro has described in his plan.
Retro - You definitely got your timing right... I got slammed soon after I finished up that set of TB's for you. You are correct in saying my bike is not finished yet either. I got busy with the parts manufacturing and building bikes for other people and have not had much time to build my bike. I work on it a bit here and a bit there when I can afford some time. I have some bigger plans for it than what I originally planned for it. So it's on the back burner for a while till I can devote some more time and funds to it. It will definitely be an attention grabber....
Timbo - As you said, it is neither cheap nor easy.... I would be happy to work with you and discuss putting everything together for you. Just shoot me a PM and we will chat.
VISIT OUR WEBSITE!
Facebook:
Instagram:
« Reply #599 on: February 10, 2017, 02:37:12 PM »
Bigger plans eh..?   Spill the beans..... ;D
