Author Topic: Installing carbs  (Read 3566 times)
Offline Blueridgerunner
  • CB650 no longer, but do have an 87 GL1200
Installing carbs
« on: February 07, 2008, 01:04:28 PM »
Which is easier, putting the boots on the engine or on the carbs first? Tried to do a search, but it wouldn't let me.   ???
Said James "In my opinion,  there's nothing in this world, beats a '52 Vincent and a red headed girl"
Laissez les bons temps rouler
Offline dusterdude
Re: Installing carbs
« Reply #1 on: February 07, 2008, 01:21:03 PM »
engine
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
« Reply #2 on: February 07, 2008, 02:30:02 PM »
+1
It helps to orientate the carb-engine boots so they are exactly linear -this will help getting the carbs on easily with no air leaks. Even better if boots are new!
Good luck
Andy
« Reply #3 on: February 07, 2008, 02:55:48 PM »
boots are new. Thought I might spray some silicone to help ease things along. Thanks for the tips
Offline sandcastcb750
« Reply #4 on: February 11, 2008, 07:06:21 AM »
Put the boots on the engine first. This way theboots are pointing perpendicular from the engine where the carbs fit in. Boot to carb first creates an angle situation which is difficult.
Sometimes I use WD40 which helps slide the carbs in.
The best time to re-attach the carbs is in warm weather because the rubber is softer. Out in the hot sun, the black rubber is more pliable, easy to push into. Obviously, now, in the winter, it is cold and the rubber is really hard. Recently, I re-attached the carbs and picked a day where the temp was 40+F and used a hair dryer to warm the boots.
Usually, I used a rubber hammer to carfully pound the carbs into the boots. Go from side to side and work the carbs in; #1 then #4, and #1 and so on.
Even if the boost are new, they are hard in 70F weater and even harder when colder. I bought new ones and decided that the old ones are no worse to use with sufficient heat.
« Reply #5 on: February 11, 2008, 01:31:14 PM »
Got the carbs on ok. Took  awhile for the carbs to fill with gas. Choke on (cold natured little buggers aren't they?) Bike fired up, idles smooth good throttle response & all pipes are warm. I am a happy man  ;D
