Author Topic: stainless bolts  (Read 1801 times)
Offline bert96
  • past ride
stainless bolts
« on: February 08, 2008, 12:48:16 PM »
 Where can i find these bolts in stainless(#18)  ???
QA50 1969,ST-90 1974,mb5 1982,rz350 1983,shadow 1100 1985,vf1000f 1985,BMW K1 1990,shadow tourer 1100 2001,vfr 750 1994,vtr250 199?
Offline 750essess
  • Orleans Cycle Repair & Resto
Re: stainless bolts
« Reply #1 on: February 08, 2008, 12:51:15 PM »
I tried to find those at one time also, they are 10mm by 1 thread shouldered IIRC. They hard to find just plated too. I got plated ones from fastenal, but they didnt have stainless. The plated ones also had a bigger head on them also.
Orleans Cycle Repair and Restoration
76CB750F
69Z50
XR650L
Re: stainless bolts
« Reply #2 on: February 08, 2008, 12:53:28 PM »
You can try McMaster-Carr, but youwill have to buy more than one. If yours are rusty you can wire brush them and paint them.
Offline bert96
  • past ride
Re: stainless bolts
« Reply #3 on: February 08, 2008, 12:53:47 PM »
 I also find them zinc plated,it's better than my old one but it's not the best,i don't like rust >:(
Offline 750essess
Re: stainless bolts
« Reply #4 on: February 08, 2008, 12:55:06 PM »
Me either, I replaced all could get with stainless on my bike.
76CB750F
69Z50
XR650L
Offline bert96
  • past ride
Re: stainless bolts
« Reply #5 on: February 08, 2008, 12:57:44 PM »
I've just check McMaster-carr they have it in stainless but with 1.50 thread pitch and i think the bolts i want are 1.25 ???
Offline Steve F
Re: stainless bolts
« Reply #6 on: February 08, 2008, 01:06:26 PM »
Had a hard time finding them anywhere, but got some "flanged hex head" in zinc plated.  Best I could do.  No socket head anywhere.  Seems Honda (or NISSIN) had them made special.
Offline bert96
  • past ride
Re: stainless bolts
« Reply #7 on: February 08, 2008, 01:10:39 PM »
I know i can have them on YAMIYA  site but at $20 each!!! i think i will stay with my zinc plated until i find them cheaper ;D
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
Re: stainless bolts
« Reply #8 on: February 08, 2008, 01:31:27 PM »
Be very careful when replacing high tensile steel bolts with stainless as the material is not as strong as HT steel. This could be very important in applications such as the two bolts you describe.
Having said that, the bolts screw into a piece of aluminium - hardly the stongest of materials.
Read the FAQs put up by the major suppliers. Here's one from Inox in the UK:
If Stainless isn’t as strong as high tensile steel is it going to be strong enough?
This is our MOST faq. Firstly it should be made clear that if for whatever reason you require high tensile (HT) bolts you should use original equipment. Secondly if we believed a bolt was not strong enough for a particular application we would not sell it to you. HT steel is used by factories because it is cheap, convenient and saves assembly time. We ran a motorcycle fitted with standard A2 bolts on discs and fork castings etc which were tested on a daily basis for many months and found no problems whatsoever. Not really a surprise when you consider both the hub and the yokes are low tensile cast alloy - the threads on the fastener are actually stronger than the threads in the material. If you need further reassurance - in the seven years we have been selling stainless we have not had a report of a single failure because the bolt wasn’t strong enough
You'll note that they cover themselves by firstly advising that you use OEM - then go on to say that their SS bolts are better!
Any metallurgists out there care to comment?
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
Offline Steve F
Re: stainless bolts
« Reply #9 on: February 09, 2008, 02:14:06 AM »
Are you're not missing the bolts, I would consider re-plating them if you're looking to keep the original "look".  I might have this done at a later time, but for now, the flanged hex head zinc plated bolts are working out fine for me.
Re: stainless bolts
« Reply #10 on: February 09, 2008, 06:21:42 AM »
I am nit a metallurgist but I work in the Railcar Industry and we by law must use graded bolts and give stated torque values for each bolt. We build the cars using a high tensile stainless. However, all of our critical fasteners are grade 8 plated steel bolts. In my own case I simply cleaned mine up and reused them for that reason. You can get graded SS bolts, but they are very expensive. For this application you can properly sized SS bolt and be fine. They are huge bolts, Honda did not kid around on those babies. I would just clean them and paint if needed.
Offline Gregorymoto
  • SOHC Aficionado
Re: stainless bolts
« Reply #11 on: February 09, 2008, 06:58:32 AM »
Yes they will be strong enough
Tacoma Screw Products Incorporated
(206) 632-7565
3930 Leary Way NW
Seattle, WA 98107
SOCKET HEAD CAP SCREW , they have ss cost you about 2.00 each if i remember right.
Good luck
G. Mountain
Yep, i have issues with this sort of stuff.
