Author Topic: what is this? does it belong to the fork?  (Read 1060 times)
Offline mazingerzeca
« on: February 08, 2008, 05:23:48 PM »
Finally, I managed to disassemble the Paioli fork of my Honda cb 125s. After separating and washing the parts of the left fork, I found this thing on the sink. I don't know if it belongs to the fork, because I was washing some other parts that day. I searched for the same thing on the other fork, but I didn't find it. It seems to be like a cotton washer. Has anyone found something like this on a fork? If so, what is this for? Is it an important part, given that the other one seems to not have it?
Thank you.
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
Re: what is this? does it belong to the fork?
« Reply #1 on: February 08, 2008, 06:58:33 PM »
Looks a bit like something you'd find around a drum brake cam shaft - my Yamaha front drum has little fuzzy 'o-rings' around the shaft where it exits the hub to prevent dust etc. from getting in there.
Roule comme dans les annĂ©es 70...   Roll as in the Seventies...
« Reply #2 on: February 09, 2008, 03:53:24 AM »
That sounds logical. The same day I was washing the rear brake drum and shaft. It probably went from there. Thank you.
Offline Raul CB750K1
« Reply #3 on: February 09, 2008, 03:16:07 PM »
It is called "felt washer" -arandela de fieltro-, and as indicated, they are on the shaft that actuates on the brake shoes. FWIW, I replaced mine for original Honda washers, but mine were white, and though used, far from that "black". Nevertheless, the swingarm had two felt washers and they were that black.
