Author Topic: sohc 750 k4 lazy oil light  (Read 1140 times)
Offline neil10
« on: February 09, 2008, 04:56:07 PM »
oil light does,t immediately come on but will after starting  for a few minutes ,.
Offline Bob Wessner
  • "Carbs Suck!"
Re: sohc 750 k4 lazy oil light
« Reply #1 on: February 09, 2008, 04:58:21 PM »
It should come on immediately when you turn on the ignition (lamp test mode) and go out as soon as oil pressure exceeds 7#'s or so.
Offline coyotecowboy
  • Easily Distracted
    • American Legion Riders Post 69 Medicine Lodge, Ks
« Reply #2 on: February 09, 2008, 06:04:36 PM »
Mine only works after its been started and warmed up a little, then kill it and the light pops on.  When its cold it won't do anything
The adventure begins when things stop going as planned - Glen Heggstad
http://www.alrpost69.com/
Sunrise Orange 750 K2
1981 Husqvarna 430 XC, "Inga"
Offline neil10
« Reply #3 on: February 09, 2008, 11:50:28 PM »
yep thats what mine does
Offline mark
« Reply #4 on: February 09, 2008, 11:58:55 PM »
(1) Remove wire from oil light switch/sender.
(2) Turn key on.
(3) Momentarily ground the disconnected wire and observe the light. It should light right up when you ground the wire. If not, replace the switch/sender.
Happy trails.
F you mark...... F you.
Offline 6adan
« Reply #5 on: February 10, 2008, 05:42:01 PM »
Mine has been doing that for a long time so I put a gage on it just to know for sure.
1970 CB750 JDM,1975 GL1000, 1979 GL1000, 1979 CBX, 1995 GL1500, 2000 GL1500CT Valkyrie, 2008 GL1800 Trike.
Offline jonbuoy
    • My rebuild:
« Reply #6 on: February 10, 2008, 07:09:40 PM »
Mine was doing the same, I took it out and gave it a few taps on the floor, been working sweet ever since.  Contact resistance went from a few Kohms down to half an ohm.  Might be worth giving it a try with yours.
Offline neil10
« Reply #7 on: February 10, 2008, 10:35:05 PM »
yeh  y not  thks
Offline jonbuoy
    • My rebuild:
« Reply #8 on: February 11, 2008, 12:55:43 AM »
Its an awkward SOB to get out - you won't have to drain the oil.  Hard part is finding a wrench to fit it and the area around it.  I resorted to grips, I hate using butchers tools like that but couldn't find any other way.
