Author Topic: wiring, plumbing problems  (Read 2529 times)
troppo
« on: February 09, 2008, 06:50:19 PM »
G`day guys
seems the PO didnt know what he was doing with the bike, the wiring is a mess, front brake hose is routed so it rubs and binds when you turn and the clutch cable is the same...
i`ve done a search and unless i missed something i couldnt find any diagrams to show me the original wiring/plumbing/cable routing through the headset and headlight bowl. if anyone can point me in the right direction for some pics or images that show the original routing of the whole mess it would be appreciated
the wiring is totally screwed up, when i hook it up according to the wiring diagram (thanks jona) i have blinkers working but the instrument lights flash too............
i`m no sparky but i`m not an idiot or colour-blind, have i screwed up some-where or is this something i should strip the harness out for
cheers all
troppo
oops almost forgot, its a 76 f1 750
« Last Edit: February 09, 2008, 06:56:57 PM by troppo »
troppo
Re: wiring, plumbing problems
« Reply #1 on: February 09, 2008, 10:22:55 PM »
so lets see, 26 views no responses
is this because no one is able to help, or just unwilling?
am i not accepted here yet?
i am asking questions because i need to know, you guys seem to know everything there is to know about these bikes and yet no-one is bothering to post a reply
if i`m posting these sort of questions in the wrong place, tell me and i`ll post elsewhere, if i`m not welcome tell me and i`ll leave
Offline Klark Kent
« Reply #2 on: February 09, 2008, 11:09:09 PM »
i think you're problem is twofold.  first off, you have an intriguing thread title.  thus the 26 views in 3.5 hours with none amongst that can answer your questions.  second, its a really confusing question.  is it a brake hose problem or a wiring problem?  or are you really running the brake hose through the headlight bucket?  the blinking instrument lights are interesting too.  maybe spliting up the issues and asking more specific questions would get you quicker replies to each isolated problem clearly put forth.
ok maybe threefold- you need to be more patient.  while there are members here who can solve your problems- as convolutedly stated as they are- they might not have been online during those few hours and might not appreciate your badgering when they do come across your post.
pics are always helpful too.  if you post a pic of the way your cables and hoses are routed i doubt you would have to wait long for someone to tell you they are routed wrong as  this forum is full of folks who can visually distinguish a badly routed cable but seriously lacking in mind readers and visionaries.  although im sure they exist.
good luck with your issues, but like the 30 odd folks who came before me i can't offer any other useful advice, other than to wait until twotired logs on and hope he is as intrigued by a motorcycle with plumbing issues as i was.
-KK
-KK
75 CB550k
95 KLR650
www.blindpilotmovie.com
download the shop manual:
you'll feel better.
listen to your spark plugs:
Offline mark
« Reply #3 on: February 09, 2008, 11:13:08 PM »
Howdy!
I'm going to guess that your post got read by a bunch of 400 and 550 owners who saw 750 at the end and figured they couldn't help.
The blinker thing sounds like a blinker isn't grounded. There should be lots of 750 pix in the gallery and lots more in project threads.
Happy trails.
F you mark...... F you.
troppo
« Reply #4 on: February 09, 2008, 11:37:12 PM »
OK, maybe i jumped the gun with my second post, but i thought my question was fairly clear, i am looking for images (pics or drawings) of the headlight area to know where to run what wires, cables and hoses
the PO had the front brake hose rubbing against the sheet metal headlight mount and it had worn through the outer rubber housing and starting to rub on the fabric lining, so i know i ned a new one but i want to be able to see where it should be run so this doesnt happen again, he had also made a mess of the wiring and i thought a couple of clear pics would help me route things where they should go so theres no problem with anything chaffing.
i`m going to take the loom off the bike and fit it again with attention to all joins, earth points etc.
as for pics its a bit late as i have removed the headlight bucket, disconected the front brake lines  and unhooked all the wiring, tacho and speedo cables and thought a few pics would simplify the process of re-installing it all properly
cheers
troppo
Offline 750goes
  • it will live
« Reply #5 on: February 09, 2008, 11:44:12 PM »
mate, I'll try and find some pictures for you......of the brake and clutch routing.....
I found some - they are in a pdf file about 6mb  in size - if you give me your email I will send it to you.
item is located on page 119 and the picture is figure 11-9.
Offline neil young
  • striving to be an
« Reply #6 on: February 09, 2008, 11:51:15 PM »
-KK
+1....i'm a plumber by trade and i was just as intrigued by the title of the thread.
sorry i'm a 550 guy so i cant help.
1972 CB500 k1
1974 CB550
1977 cb 550
2008 Triumph Scrambler
« Reply #7 on: February 10, 2008, 12:39:29 AM »
I simply don't believe you've hooked it up per the Honda Factory wiring diagram.
Just doesn't seem likely Honda delivered a bike that worked in such a fashion.
Did you confuse Gr with G?
troppo
« Reply #8 on: February 10, 2008, 12:43:49 AM »
well the wiring diagram i have isnt the clearest but i have connected them as i read them, they all seemed to match up colour wise (wiring colours), i doubt honda would build a bike like that but i`m fairly sure the PO has done something to cause it after the mess i`ve already removed
i`ll strip the harness out and check for any hidden modifications and bad earths
cheers
troppo
Offline spitfire
« Reply #9 on: February 10, 2008, 03:38:40 AM »
Hi there, finished restoring my 76 CB750 F1 last year, have attached some diagrams from the F1 manual supplement and parts book, I can also attach some photos of my F1 if that is not enough. The wiring diagram has "boxes" which show where the wiring is physically located as well if you look closely.
Cheers
Den
Wirral UK
1976 CB750F1 bought new in 76
1977 CB750F2: Restoration started
1964 BSA A65R: Waiting restoration
My gallery is here: http://www.sohc4.us/gallery/v/members/personal/spitfire/?g2_navId=x5a30f7b6
troppo
« Reply #10 on: February 10, 2008, 03:46:40 AM »
thanks spitfire
the manual copy i have doesnt have too many decent images, these are the sort of things i was looking for, i need to replace the top hose for the front brake because of the PO`s routing, and his wiring was "creative" to say the least lol
I would appreciate a couple of pics of your bikes headset area, my manual is a generic (and a photocopy, got to look for a decent real one)
your helps appreciated mate
cheers
troppo
« Last Edit: February 10, 2008, 03:52:03 AM by troppo »
Offline spitfire
« Reply #11 on: February 10, 2008, 04:54:39 AM »
Here's a quick one of the finished result, I'll dig through the in progress shots to see if there is a clearer one.
Cheers
Den
Wirral UK
troppo
« Reply #12 on: February 10, 2008, 05:10:05 AM »
thats one hell of a bike there spitfire, i`m jealous now, my bike is a little rougher than that
i`m looking to find things like the throttle cable routing etc, that pic shows me the PO had it wrong at the headlight for a start, so any chance of pics of the frame routing?
i`m not looking at doing a full restoration but i want this to be a decent bike and i figure honda spent plenty of money on that so i should route the wiring and cables (and plumbing) the same way they did
cheers
troppo
Offline spitfire
« Reply #13 on: February 10, 2008, 05:39:58 AM »
Here's some of the frame run.
Cheers
Den
Wirral UK
jus750
« Reply #14 on: June 27, 2010, 05:29:27 AM »
Thanks Spitfire a heap, was having trouble with my wiring harness rubbing against the tank, from your pictures I realised I had routed my cable wrong, Was doing my head in trying to figure it out untill I stumbled onto ths post.
 your a legend oh and nice bike. pics will be up of mine soon
