Author Topic: CB750 K0 Gearbox - is it inter changeable  (Read 2269 times)
Offline chaintong
« on: February 10, 2008, 11:56:51 AM »
Hi there,
My Cb750 will always jump out of fourth. I can live with it, but I really need to do something about it... I have been looking on ebay for a whole 750 engine but they don't come up very often in the uk.
Does anyone know if
-1- I can still get the parts from Honda?
-2- there are any other engines with the same gearbox internals? cb750 dohc? cb 900? cb 550?
thanks for any advice
chain
Offline Gregorymoto
  • SOHC Aficionado
Re: CB750 K0 Gearbox - is it inter changeable
« Reply #1 on: February 10, 2008, 12:05:08 PM »
I know this, the DOHC gearbox woll not work on a SOHC.
As far a fix i would look at the M3 racing websight, they cane help you fix your gearbox giving it a vast improvment over the  stock clunky CB trans.
Good luck
http://www.m3racing.com/
Yep, i have issues with this sort of stuff.
Offline Johnie
« Reply #2 on: February 10, 2008, 02:38:47 PM »
Swoop...what did those shocks cost you from the dealer?
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Patrick
« Reply #3 on: February 10, 2008, 03:08:19 PM »
According to Hondaman, the gear boxes of 1969 to 1978 SOHC 750s will interchange. The only difference between the K0 gear box and the later ones was the gear bushings in the K0 were brass and didn't wear as well as the later bushings. I confirmed the brass bushings when I pulled the tranny from my K0 last year. Even though it was in great shape, I replaced it with a tranny from a later bike without brass bushings. It was a direct swap.
Patrick
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
« Reply #4 on: February 10, 2008, 10:04:05 PM »
There are some odd changes and mods through the years but a complete set is usually OK, Where in UK are you as i have a 750 engine on the bench to rebuild as a spare!
You can call me on 07795162623 any EVENING Sunday to Thursday inclusive.
Offline chaintong
« Reply #5 on: February 11, 2008, 01:52:52 PM »
hmm I guess i'm looking for a  SOHC then..
Thanks for the help as always...
bryanj  I'm not far from J19 M6, I'll ring /txt you after thursday.
cheers
Offline Clyde
« Reply #6 on: February 11, 2008, 07:45:49 PM »
If you interchange the whole gear box there should be no problem.
The F (75-78) gearboxes used different 4th or 5th gear ratios from memory. No great difference but you must obviously get matching countershaft and main shaft gears.
I would have to check- but the K7 and K8 also used a lot of 76 750F/F1 parts so be careful if you start mixing and matching.of parts
Another point to watch is that the final drive shaft gears are different on the later boxes -43/50 on the F1 and 48/56 on the early K's. Roughly the same ratio but not capable of being mixed and matched.
Regds
Clyde
SOHC4 #1909
Honda CB750 K0(original and unrestored), K1(in pieces), K2(restored), F1(restored), 76 750a (awaiting restoration), 1966 Honda CB72
Suzuki GT750 1972 (restored), Kawasaki Z1 1973 (restored)
« Reply #7 on: February 11, 2008, 08:52:02 PM »
DONT RING AFTER THURSDAY only between Sunday-Thursday!!!
Dearly beloved gets anti if i start talking bikes on our time off
Offline ken736cc
  • When the cops pull me over, I usually let them off with just a warning.
« Reply #8 on: February 12, 2008, 09:24:53 AM »
There are many differences in early gear boxes. Most gears for early models are no longer available. If you are using new gears or good used parts from another bike, count the number of teeth. Lots of gears have been changed by 1 tooth.
K0 sandcast(in process of restoration), K0 diecast, K0 cafe racer
BMW R69S daily rider, 71SL350, 71 SL100, 63 SS50
Offline Raul CB750K1
« Reply #9 on: February 12, 2008, 12:50:44 PM »
Mine gets mad anytime of the week!   ;D
Offline Patrick
« Reply #10 on: February 12, 2008, 05:30:24 PM »
I agree, Raul. I think Bryan is pretty lucky if he gets a pass Thursday through Saturday, as long as people don't call about bikes....
I wish I could get a consistent pass between, say, noon and 12:05 p.m. on Thursday alone.....
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline cafe750
  • If you can't fix it with a hammer, it's electrical
« Reply #11 on: February 12, 2008, 09:08:47 PM »
 Mine enjoys going on parts runs with me, and digging through boxes o' parts for that one piece of unobtainium that may be lurking in there...It may also help that she enjoys riding too... :)
"It's an old motorcycle, the wind is supposed to blow your head around, it's supposed to leak oil, the brakes should suck, and every now and then, it should scare you so bad you piss your pants."
Roy, Washington
« Reply #12 on: February 12, 2008, 09:11:30 PM »
Well I cant really complain---She did pay for No36 for my 50th birthday, which is why the insurance were told to go away (but not in those words) when they wanted to crush it after it was torched
« Reply #13 on: February 13, 2008, 07:16:25 AM »
Remember sprocket shaft is longer in 77/78...
Offline chaintong
« Reply #14 on: February 13, 2008, 02:43:41 PM »
bryan....
sorry I completely mis read you post, I ring tomorrow.
cheers
Offline chaintong
« Reply #15 on: February 14, 2008, 03:49:49 PM »
and again...i only got in  at 23:15.... a bit too late to ring i think..... next week then
« Reply #16 on: February 15, 2008, 08:30:35 AM »
It would have been OK mate---I work permanent nights!!!! try Monday as i am supposed to be siting in our security hut instead of driving, something about foxes and hen houses comes to mind!
