Author Topic: Russian four wheeling  (Read 793 times)
Rocking-M
« on: February 13, 2008, 06:13:36 PM »
Check out the ground clearance and the axle set up.
http://englishrussia.com/?p=1766#more-1766
Now I'd like to see a schematic on the power transmission to the wheels.
Came back to add this link,
http://englishrussia.com/?p=1447
« Last Edit: February 13, 2008, 06:22:17 PM by Rocking-M »
Offline SEBNN
Re: Russian four wheeling
« Reply #1 on: February 13, 2008, 11:56:48 PM »
It looks like two sets of beveled gears (make 2 90deg power transfers).  Others use a simple setup involving a couple of spur gears which seems easier and has a good final gearing reduction.
Offline UnCrash
  • Pass
    • My Blog
« Reply #2 on: February 14, 2008, 05:41:28 AM »
Monster Ambulances!
Man, what a rough ride that would be...
Offline DarkRider
« Reply #3 on: February 14, 2008, 05:44:15 AM »
heh Portal Axles....Simular to whats under a Unimog.
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
Rocking-M
« Reply #4 on: February 14, 2008, 12:52:05 PM »
I assumed it was some kinda bevel gear also, is that what it is Outlaw?
Offline DarkRider
« Reply #5 on: February 14, 2008, 05:12:42 PM »
Portal axles use bevel gears in them but they have offset hubs like whats shown under those trucks. Basically the main axle housing is up above the wheels like that for ground clearance.
Here is a brief explaination of a portal axle as well as a site that explains the unimog.
http://www.west-4x4.demon.co.uk/portal.htm
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
