Author Topic: stupid piston ring question:  (Read 1857 times)
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« on: February 14, 2008, 02:03:26 PM »
i've never used one-piece oil rings (i know, i should be using three piece, but it's what i have). My question is: does the spring ring go behind it with the gap opposite the gap in the ring? I managed to get the cylinders over them, but they sure seem a tight fit. end gap measures at .007 in the cylinders, which i believe should be just about dead on (.003 gap per inch of bore, right?).
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline mkramer1121
Re: stupid piston ring question:
« Reply #1 on: February 14, 2008, 04:20:12 PM »
yes, the spring ring goes behind the large solid ring
Offline paulages
  • 1976 cb735
« Reply #2 on: February 14, 2008, 04:29:45 PM »
i just wanted to make sure that the gap in the spring shouldn't line up with the gap in the ring itself. i installed it this way, and the pistons seem to travel up and down the cylinders appropriately.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline mkramer1121
« Reply #3 on: February 14, 2008, 04:53:43 PM »
that's what i did and the 750 runs fine
Offline paulages
  • 1976 cb735
« Reply #4 on: February 14, 2008, 10:59:18 PM »
thanks- bought some rings from rusty riders and didn't realize the oil rings were one piece until i got them. the picture was for three piece oil rings.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
« Reply #5 on: February 14, 2008, 11:18:43 PM »
Paul, I've never seen a one piece ring with a spring ring behind it. I had some bad dealings with that outfit as well, wouldn't buy from them again. >:(
Sam. ;)
Offline mkramer1121
« Reply #6 on: February 15, 2008, 04:54:50 AM »
Paul,
If you complain to them about it, they will offer you a (partial) rebate, same thing happened to me as well.  They changed the picture on the 750 ring to the 1 piece picture after I complained.
Offline dusterdude
« Reply #7 on: February 15, 2008, 07:01:25 AM »
Sam. ;)
yea,me neither,my harley rings didnt have a springy thing.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline paulages
  • 1976 cb735
« Reply #8 on: February 15, 2008, 09:20:47 AM »
Sam. ;)
well now you guys are worrying me. it was a really tight squeeze for sure, but the pistons travel pretty freely in the bores turning the stator by hand.
mkramer- you used the exact same rings? did you find it difficult to get the pistons in the bores at the oil ring? granted, i used my fingers rather than a ring compressor, but damn it wasn't easy. me like three piece oil rings.  >:(
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline dusterdude
« Reply #9 on: February 15, 2008, 09:35:44 AM »
i will say i like the idea of a spring behind the oil ring,should help keep it from sticking,like mine did.
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline mkramer1121
« Reply #10 on: February 15, 2008, 12:44:33 PM »
Sam. ;)
It was my first rebuild, so whatever was difficult, etc., I don't have a baseline to compare it to...I used my fingers too.
Offline paulages
  • 1976 cb735
« Reply #11 on: February 15, 2008, 02:27:09 PM »
Sam. ;)
well it's funny, 'cause i only have modern three piece rings to compare to. showing my age i guess.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
