Author Topic: Carb inlet tee o-rings  (Read 1061 times)
kaysystems
« on: February 16, 2008, 07:18:39 PM »
I need help to get some O-rings for the carb fuel inlet tee.
Part number 16173-044-004
Supposedly unobtainable, but Speed Supplies in Oklahoma has them listed for 28 cents each
go here (this may appear on 2 lines, but it all gets typed in as one)
http://www.speedsupplies.com/partslisting.asp?position=487&increment=500&category=HN
They have a minimum order of $20.00
I could do this (72 O-rings) but they then want $47 to ship to Canada!!!
Anybody out there willing to get some O-rings for the guys here on the forum?
I need 8
thanks
David
Offline Badger 5
    • Gallery
Re: Carb inlet tee o-rings
« Reply #1 on: February 16, 2008, 07:22:04 PM »
My sister lives pretty close to their location.  I could see if she could pick them up and mail them to you.
76 CB550K
75 CB200T
68 CL160 (AHRMA R78)
07 Triumph Bonneville Black
75 XS650
Offline Bodi
« Reply #2 on: February 16, 2008, 07:40:58 PM »
This is a standard O-ring, as metric O-rings go. There are about 500 inch size "standard' O-rings that are used in 99.9% of inch-size machinery... but a multitude of metric sizes - thousands and thousands of sizes. The one you want is a P-8 size JIS standard O-ring (7.8 x 1.9mm), they should be available from most industrial suppliers. There are still a lot of JIS sizes but this one isn't a real oddball, at least. You just need gas-proof, viton is probably best. You'll probably run up against a minimum sale, but that should be less that their minimum and shipping. Where are you in Canada? I know a good O-ring shop in Toronto.
tbone
« Reply #3 on: February 16, 2008, 07:45:16 PM »
Forget the bike shops. try auto parts stores, hardware stores and plumbing supply stores.
Neoprene o-rings are all basically the same. bring a tee with you and check the fit.
You should get out of there for a couple bucks max.
