Author Topic: Replace stock filter with foam?  (Read 3981 times)
Offline Harry
    • CB500F
« on: April 10, 2005, 01:53:30 AM »
Is it possible (recommendable) to remove the paper from the air filter and replace it with a pice of foam cut to the right size and "squeezed" with oil?
Harry Teicher, member #3,  Denmark....no, NOT the capital of Sweden.
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
Re: Replace stock filter with foam?
« Reply #1 on: April 10, 2005, 02:49:52 AM »
K&N used to make a washable replacement for the stock item. Best of both worlds.
Don't know if you can still get them though.
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
Offline cben750f0
« Reply #2 on: April 10, 2005, 05:59:17 AM »
you can still get UNI filters off ebay, new in plastic wrap... washable, am running one in the F1... looks like good quality, and again, you can wash it and reuse it... nice.... may need to jet it up though... peace
Ibsen
« Reply #3 on: April 10, 2005, 06:46:40 AM »
If you are to replace the paper with foam, you will have to find a type of foam that have enough air flow, and will filter properly at the same time. However it is possible on some filters to cut awy the old paper and replace it with airfilter paper from a car filter. But again, the problem is finding a paper with enough air flow. The paper in car filters are often a bit more restricted than in MC filters.
The UNI or KN washable filters for the stock airbox, is a very good alternative. They offer better airflow than the stock filter, without the disasvantages of the pod filters.
Offline Einyodeler
  • Midnight bugs taste best!!!
« Reply #4 on: April 10, 2005, 06:50:33 AM »
Hey Harry
I`ve been running Uni filters on my bikes for years and you can`t beat them,just wash them out and reoil and they are like new.You can buy the foam matting in sheets and make your own,I`ve had to do that quite a few times on some of my older machines that you can`t get parts for anymore.The important thing is to get some chicken wire or likewise and form that along the inside of the matting so the foam doesn`t get sucked in to the carbs,ask me how I know :P
Cheers,Stephan
1972 CB500 - 1973 CB500 - 1974 CB550K - 1975 CB550F - 1975 CB750F - 1976 CJ360 - 1983 CR480 - 1970 BSA A65T Thunderbolt
Download Motorcycle Shop Manuals here: http://forums.sohc4.net/index.php?topic=17788.0
Offline cben750f0
« Reply #5 on: April 10, 2005, 09:19:44 AM »
ok how do you know ???    8)
Offline Dennis
« Reply #6 on: April 10, 2005, 09:42:55 AM »
K&N are available for the 750's, just bought one not too long ago. Don't seem toi be available for the 500's though and I think that Harry has a 500!?
As mentioned UNI is available brand new for the 500/550. Might be exactly what you are looking for!
Offline fergie
« Reply #7 on: April 10, 2005, 10:05:34 AM »
Harry,I actually tried to do this about 2 weeks ago,I needed a new filter and was going to replace it with a uni or K&N filter,but I did not know if I needed to re jet the carbs or not , I really didn't want the hassle,so I  bought a new filter from honda. Just for kicks, I cut the paper out of the old filter to see if I could replace it with some uni foam I had around the shop.Well, this experiment did not go well at all. After cutting the paper out of the housing what remained was a thick yellow glue that is impossible to get off.If I could get that glue off I could probobly make it work, but with it on, I don't think it would be a smooth enough surface to glue the new foam to.Anyway the new filter works great so it all turned out well.the old filter is in the trash. Good Luck ,Fergie.
The most interesting man in the world
Offline Kevin D
  • SE Michigan
« Reply #8 on: April 10, 2005, 10:45:01 AM »
After my 30 year old foam air filter deteriorated, I went to the local Sears and got a tractor filter that was just a little bit bigger. I cut it to size, glued it with Pliobond contact cement, and fit it over the old frame..  That was about 3 years ago, and it works fine.
71 CB750 K1
105,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline Harry
    • CB500F
« Reply #9 on: April 11, 2005, 07:01:41 AM »
Well, I cut out the paper filter element and the housing fell apart in my hands. Obviously, the paper/glue holds everything together. Found a nice thick piece of foam from a parcel I hade received earlier & cut to size. Oiled foam, fitted everything together w/out glue as the airbox is so snug it holds the whole filter together. Seems to work ok.....
Offline cben750f0
« Reply #10 on: April 11, 2005, 03:53:46 PM »
harry you want to be carefull your motor dont suck up the foam... thas what the mesh is there for.... beware... peace
