Author Topic: bt45 tyre 120  (Read 1139 times)
Offline neil10
bt45 tyre 120
« on: February 17, 2008, 06:55:15 PM »
is a 120 wide tyre ok on the  sohc 750 k4   thks
Bob550four
Re: bt45 tyre 120
« Reply #1 on: February 17, 2008, 07:14:47 PM »
on front or rear?
Re: bt45 tyre 120
« Reply #2 on: February 17, 2008, 07:58:56 PM »
Rear it will fit fine but if I were you Id fit the stock rear size - 110 - Ive done this on my K2 -  works great. 120 will stretch it a little more and so will wear a llittle more in center. Will still work of course.
cheers
Andy
Offline tinyrobot
  • Mock it up before you Fock it up!
    • ChiVinMoto
Re: bt45 tyre 120
« Reply #3 on: February 17, 2008, 09:11:08 PM »
No info to add about the size, but if you are shopping for the bt45s check out my post.  I just picked some up at a really good price.
http://forums.sohc4.net/index.php?topic=30884.0
Offline FunJimmy
  • Who you calling
  • Vancouver
Re: bt45 tyre 120
« Reply #4 on: February 18, 2008, 12:11:06 AM »
According to Bridgestone the minimum rim width for the BT45 120 is 2.5" and recommended width is 2.75".
That's almost 1" wider than you have available.
http://www.motorcycle-karttires.com/glamourindex.aspx?productID=3&LookupID=8
Offline Steve F
Re: bt45 tyre 120
« Reply #5 on: February 18, 2008, 02:40:09 AM »
a 120 on the rear should work fine.  That's what I have.
Re: bt45 tyre 120
« Reply #6 on: February 18, 2008, 10:10:22 AM »
Depends on your value of "work".
Can they be mounted and will they roll - yes.
Do you have to run at elevated tire pressures to keep the well stiff - yes.
Will they center wear much more rapidly than a tire with the proper rim width - yes.
Do they cause strange handling behavior when such abnormal wear occurs - yes.
Will they still roll when they have abnormal wear - yes
Will the rider adapt to the slowly deteriorating handling behavior - usually.  And then sing praises of how much better their brand new replacement tire is, than that old piece of crap they suffered with for far too long.  :o
(I may have embellished a bit of the above.)  ;D
BTW, I've had 120s, too.
