Author Topic: Shelf life - Oil  (Read 944 times)
Offline CaféElite
  • 1975 CB550
Shelf life - Oil
« on: February 18, 2008, 04:18:59 PM »
Im curious if unopened oil has a shelf life? I have about 12qts of oil that have been setting on my garage shelf for like 2 1/2 years and finally found a reason to use it.. Now im curious if I should since I dont if its still good.. Might sound like a door knob of a question but *shrug* I have no clue.
Thanks..
CB550's
Kansas City..
Religion is like masturbation, do it at home and keep it to yourself
Offline Roach Carver
Re: Shelf life - Oil
« Reply #1 on: February 18, 2008, 04:30:14 PM »
I would say it is okay if sealed and unused.
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
« Reply #2 on: February 18, 2008, 04:35:21 PM »
"ExxonMobil recommends a five year maximum shelf-life for engine oils, including Mobil 1."
Found here:
http://www.mobiloil.com/USA-English/MotorOil/Car_Care/AskMobil/Mobil1_Shelf_Life.aspx
...I bet it's longer than that, they are in the business of selling the stuff  ;)
 Matt.
Gallery at:
Offline CaféElite
  • 1975 CB550
« Reply #3 on: February 18, 2008, 04:39:17 PM »
Thanks!!!!
CB550's
Kansas City..
Offline Uncle Ernie
« Reply #4 on: February 18, 2008, 05:22:10 PM »
Call the manufacturer.
Offline CaféElite
  • 1975 CB550
« Reply #5 on: February 18, 2008, 05:27:05 PM »
Listen here negative nancy if I wasnt lazy I would have done so. :P Actually I could have searched the net as well but sometimes you just dont get that back yard garage knowledge by going that route.
CB550's
Kansas City..
Offline 333
  • Time for change
« Reply #6 on: February 18, 2008, 05:41:06 PM »
Negative Nancy?  Boy, Ernie.  He told you!
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline Kevin D
  • SE Michigan
« Reply #7 on: February 18, 2008, 05:57:13 PM »
Not that it has anything to do with this discussion but........I wonder how long it was buried in the ground before it sat on the shelf for two years.
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
« Reply #8 on: February 18, 2008, 05:59:52 PM »
I got some Aero Red Shell oil from the 30,s..wonder if it is still good??
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #9 on: February 18, 2008, 06:28:18 PM »
I'm not sure I would trust the manufacturer. After all, they would rather sell you some new stock, right? ;)
Having said that, here's one source  http://www.carbibles.com/engineoil_bible.html if you scroll down, on various types of oils. Engine oil recommendation is three years.
« Last Edit: February 18, 2008, 06:33:42 PM by Bob Wessner »
« Reply #10 on: February 18, 2008, 07:01:21 PM »
I would not put it in newer engines like from the 1950's to the present. They had none of the additives. Our CB would chew it up in seconds. It is a great keepsake.
